    add second heater bed
    1.0k
    • yamanundefined
      yaman
      hi every one
      I try to add second heater bed but I can't add the second heater bed in web interface or reading temperature
      I have pt100 and thermocouple boards: MAX31856
      I add first heat bed without any problem I can read and run the heater
      what I want to do is read the temperature from second sensor and then turn on and off each bed split the heater bed is keenovo 220/750W so I think the thermo type K
      so please help
      this is me config is Duet Web Control 2.0.0-RC2 / RepRapFirmware 2.02(RTOS)
      ; generated by RepRapFirmware Configuration Tool v2 on Tue Dec 11 2018 13:08:00 GMT+0300 (Arabian Standard Time)
      M550 P"My Printer" ; Set machine name
      M552 S1 ; Enable network
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      ; M569 P0 S0 ; Drive 0 goes forwards=0 BACKWARD = 1 0==X
      ;M569 P1 S1 ; Drive 1 goes forwards=0 BACKWARD = 1 1==Y
      M569 P2 S1 ; Drive 2 goes forwards=0 BACKWARD = 1 2==Z
      M569 P3 S0 ; Drive 3 goes forwards=0 BACKWARD = 1 3==E
      M569 P4 S1
      M569 P5 R1 T2.5:2.5:5:0
      M569 P6 R1 T2.5:2.5:5:0
      M569 P7 R1 T2.5:2.5:5:0
      M569 P8 R1 T2.5:2.5:5:0
      M584 X7 Y8
      3M350 X16Y16 Z16 E16 I1 ; Configure microstepping with interpolation
      M92 X321 Y260 Z396.03 E500.00 ; Set steps per mm
      M566 X400.00 Y400.00 Z12.00 E420.00 ; Set maximum instantaneous speed changes (mm/min)
      M203 X2500.00 Y2500.00 Z1000.00 E1200.00 ; Set maximum speeds (mm/min)
      M201 X50.00 Y50.00 Z20.00 E100.00 ; Set accelerations (mm/s^2)
      M906 X1800.00 Y1800.00 Z800.00 E500.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X475 Y265 Z645 S0 ; Set axis maxima
      M574 X2 Y2 Z2 S0 ; Set active LOW =0 ACTIVE HIGH = 1 endstops
      M558 P5 H30 F120 T6000 ; Set Z probe type to switch and the dive height + speeds
      G31 P495 X0 Y0 Z30 ; Set Z probe trigger value, offset and trigger height
      M557 X15:195 Y15:195 S20 ; Define mesh grid
      M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
      M305 P100 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
      M143 H2 S120
      M563 P0 D0 H1 ; Define tool 0
        If heater 2 is your second bed heater, use this in config.g to enable the second bed heater:
        M140 H0:2
        • yamanundefined
          yaman
          I add this line
          but still bed 2 not shown
          • yamanundefined
            yaman
            this the line I add
            M305 P101 T100000 B4138 R4700
            M140 H0:2 s 120
              I'm sorry, I gave you the wrong command. The correct command to enable the second bed heater is:
              M140 P1 H2
              P1 means bed heater 1 (the original is bed heater 0), and H2 means use heater 2 for it.
              To get it to show up in DWC I think you will need to give heater 2 a heater name in its M305 command.
              yamanundefined 1 Reply Last reply Reply Quote 0
              • yamanundefined
                yaman @dc42
                @dc42 said in add second heater bed:
                M140 P1 H2
                witch channel is this port
                because second sensor connect with this port
                thermo type K
                • yamanundefined
                  yaman
                  I Add this code to define the Bed 2
                  M305 P101 S"Bed 2 "
                  but how to get thermo redding
                    The channel numbers for the first MAX31856 based thermocouple interface are 150 and 151.
                    • yamanundefined
                      yaman
                      150
                      I add this lines
                      M305 P101 X150 S"bed_2"T100000 B4138 R4700
                      M140 P101 H2 S120
                      but I got on screen not correct reading
                        Use P2 in the M305 command (heater 2) and P1 in the M140 command (bed heater 1).
