    hell of a bed or I missed a config step
    • Martin S
      Martin S last edited by
      Hey Guys...
      maybe you can give me a good hint on how to improve my bed situation....
      ![Bild Text](Bild Link)
      • Martin S
        config:
        ; generated by RepRapFirmware Configuration Tool v2 on Sun Dec 23 2018 12:24:41 GMT+0100 (Mitteleuropäische Zeit)
        M665 R125 L333 B115 H270 ; Set delta radius, diagonal rod length, printable radius and homed height
        M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
        M550 P"Kossel XL" ; Set machine name
        M551 P"xxxxx": ; Set password
        M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
        M586 P0 S1 ; Enable HTTP
        M586 P1 S0 ; Disable FTP
        M586 P2 S0 ; Disable Telnet
        M350 X32 Y32 Z32 I0 ; Configure microstepping without interpolation
        M350 E16 I1 ; Configure microstepping with interpolation
        M92 X200.00 Y200.00 Z200.00 E663.00 ; Set steps per mm
        M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; Set maximum instantaneous speed changes (mm/min)
        M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; Set maximum speeds (mm/min)
        M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; Set accelerations (mm/s^2)
        M906 X1000.00 Y1000.00 Z1000.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
        M84 S30 ; Set idle timeout
        M208 Z0 S1 ; Set minimum Z
        M574 X2 Y2 Z2 S1 ; Set active high endstops
        M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BL Touch
        M558 P9 H15 F2400 T1200 ; Set Z probe type to bltouch and the dive height + speeds
        G31 P50 X-27 Y-10 Z0 ; Set Z probe trigger value, offset and trigger height
        M557 R115 S20 ; Define mesh grid
        M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
        M563 P0 D0 H1 ; Define tool 0
          Phaedrux Moderator @Martin S last edited by
          @martin-s said in hell of a bed or I missed a config step:
          You are probing way too fast for a BLTouch. Try F100 instead. You also don't have a Z trigger height set in your G31. That will need to be measured using: https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
            It looks to me that you haven't run delta calibration, or if you did then you didn't save the results. See https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer.
