    DuetWiFiServer 1.22beta1 available
    Firmware installation
      I have put a beta copy of DuetWiFiServer 1.22 at https://www.dropbox.com/s/xxppv7a39g38x9s/DuetWiFiServer-1.22b1.bin?dl=0. Specifically, this fixes an issue triggered by Duet Web Control 2.0beta whereby when clients tried to download more than 3 files concurrently, the server sometimes ran out of resources and terminated the connection. However, those of you having problems getting Duet Web Control 1.x to establish and maintain a connection (other than because of poor signal strength) may also wish to try this version.
      Please report your experiences with this beta release in this thread.
      This release is interface-compatible with DuetWiFiServer 1.21. You can use it with RepRapFirmware 2.0 and later.
      • imrj
        imrj last edited by
        i am so confused with this stuff....which one am i suppose to use on my DuetWifi? the combined one and rename it to DuetWifiServer.bin or use this one you posted here? whats the diff?
          Phaedrux Moderator @imrj last edited by
          @imrj The combined firmware is the main duet firmware. It's called combined now because there used to be seperate versions for the ethernet board and wifi board. They are now combined. It also includes the maestro boards.
          The wifi firmware is seperate.
          This wifi firmware beta is for people testing the new DWC2.0.
          You can find what you need here: https://github.com/dc42/RepRapFirmware/releases
          This latest 2.02 release has simplified things greatly. You only need the first file listed. Upload the whole zip file in the DWC, and it will update everything it needs.
          • imrj
            imrj last edited by
            ok i loaded this firmware on the SD card with the proper name and this is what it shows, doesnt look righ to me?
            Phaedrux wilriker 2 Replies Last reply Reply Quote 0
              @imrj You should be able to upload this single file and it should update everything.
              https://github.com/dc42/RepRapFirmware/releases/download/2.02/Duet2Firmware-2.02.zip
              Don't unzip it, just upload it.
              • wilriker
                wilriker Moderator @imrj last edited by
                @imrj Additionally to what @Phaedrux said: just putting the files on the SD card is not enough. They need to be installed. If you upload it via DWC it will ask you whether you want to perform this update or not. In case you uploaded them any other way (ftp or removing the SD card and copying the files onto it) then you need to run M997 S0:1 to update both RRF and DuetWifiServer.
