    Help me decide which printer to put my duet in
    1
    330
    • mkellyundefined
      mkelly
      I recently purchased a duet board and I'm a bit torn as to which printer to put it into. I'm curious what other people would do
      Here's the potential donors
      Bigbox Dual extruder Kickstarter edition
      actually mine
      Pros:
      • Would benefit from quieter drivers
      • Good platform to make a tool changer / future capability
      • Already has working dual extrusion capabilities
      Cons:
      • Currently prints without major issues
      • Already runs Octopi
      • Some mechanical improvements needed on the Z
      • Extruder is bulky and due for an upgrade
      Deltamaker
      not my picture, but mine would look like this + dust
      Pros:
      • It's a delta running 8 bit and would benefit the most from 32 bit controller
      • Deltas are fun
        Cons:
      • Already has Octopi
      • Printing shows "Resonance" issue with a benchy, could be a controller issue?
      • No heated bed
      Z morph 2.0S
      actual printer
      Pros:
      • Can run a variety of extruders and tools, making best use of the Duet board
      • Not already open source, has a bad interface and they refused to offer upgrade possibilities
      • If Duet adds closed loop would be best used on this printer
      Cons:
      • Not many good options for CAM path planning to replace the (underwhelming) native software with
      • Some odd design choices in the older versions of the Z morph (2.0s and 2.0sx etc) . Needs machined component replacements
      • Closed loop upgrades to the motors will be more critical for doing any light CNC cutting
      • May already run 32 bit?
      Replicator 2 Modified with Aluminum Braces
      delay or hold back in terms of progress, development, or accomplishment
      Pros:
      • Mightyboard is having some issues after a stepper driver popped
      • Stepper drivers are loud
      • Robust and reliable mechanical platform
      • Was being upgraded to a Titan Aero before the failure
      Cons:
      • Mightyboard may be fine when replacement drivers are installed
      • Requires a new PSU or a way to use the old one
      • It's a makerbot so it's a bit 'special'
      Let me know which one you would pick. I have my favorite but I'm curious what others might select.
