    swapping out ESP module for ethernet module
    • imrj
      imrj last edited by
      am contemplating desoldering the built-in ESP12 module on my DuetWifi for with this wired ethernet module instead, I should gotten the wired version since I had the network cabling available, the wifi is just too unreliable for me but too late for that
      is this module swap advisable? any specific firmware issues or flashing of the module needed?
      https://www.amazon.com/gp/product/B01MEEIC7Z
      • resam
        resam last edited by
        I'm not sure about the module you posted link - I don't think it is compatible.
        Duet3D sells the correct ethernet module on their shop: https://www.duet3d.com/DuetAddons/DuetEthernet_Module
        If you take this one and solder it correctly, it will work. There are a few people on the forum who have already done the conversion.
          Alternatively if the problem WiFi signal strength, you can replace the ESP12S module by ESP07S + external antenna.
          imrj 1 Reply Last reply Reply Quote 0
          • imrj
            imrj @dc42 last edited by
            @dc42 ok dc...yea i got one of those too with an external antenna....i can swap it out but do i need to worry about flashing anything into the ESP07S?
              dc42 administrators @imrj last edited by dc42
              @imrj said in swapping out ESP module for ethernet module:
              You will need to copy DuetWiFiServer.bin into /sys on the SD card if it isn't already there. Then send M997 S1 from USB or PanelDue to install it on the new module.
              Make sure it is the ESP-07S that you have. The older ESP-07 won't work.
              • imrj
                imrj last edited by
                yes is 07S indeed...just got it done, piece of cake, working much better...thanks @dc42 you are a champ!
