    Its only possible to connect with wifi.
    530
    • Crax
      Crax last edited by
      got a strange Problem. On my Laptop with WLAN the Duet is shown up in the network scan and the interface is working fine. When i try to scan with my tower PC via cable Ethernet the Duet isnt shown up in the scanning result and cant connect to the web interface.
      It seems that every Device can cannoct with Wifi but not with "cabled" ethernet.
      Both PC got Win10 and firewall is deactivated.
        It sounds like maybe your router isn't bridging the ethernet and wireless interfaces.
        Can you compare the IP addresses of each device? Does each device have the same first three octets? Ex, 192.168.0.#
        • Crax
          Crax last edited by
          Yes its the same IP
          , i can see other WLAN devices like my Smartphone.
            Can you connect from your PC by entering the Duet's IP address in your browser?
            • Crax
              Crax last edited by Crax
              Dont ask me why but now it works Oo
              Thanks for the support, i hope it will work tomorow too...
              But there was another thing i have allready fixed, only for your Information.
              The soldering points on the SD Card Socket are not soldered well, got problems to read the SD Card, after resolder it the SD Card works fine
                dc42 administrators @Crax last edited by
                @crax said in Its only possible to connect with wifi.:
                Thanks for letting us know. Can you confirm that it is a genuine Duet WiFi purchased from us or from one of our resellers?
                • Crax
                  Crax last edited by
                  Sorry for the late answer, got it from reprapworld. Is it enough or do u need something like a invoice ?
                    RepRapWorld Netherlands is a Duet3D distributor, so it should be genuine.
