    Autodesk PostProcessor for RRF
    • 3DOesteundefined
      3DOeste
      Hi, I've made an Autodesk postprocessor (powermill, featurecam, artcam) that works with RRF. It's still a work in progress but so far it works.
      The only thing I was not able to remove is the G43H1 at the beginning, I'm not sure if it's post related or cam related...
      Canned cycles are dissable.
      Arcs works.
      I don't have a Duet controlled CNC yet, i'm putting my printer in CNC mode, so if someone can try it, let me know how it works.
      Change .txt extension to .pmoptz
      0_1546608412501_Duet2.txt
      • timcurtis67undefined
        timcurtis67
        G43H1 is calling up a tool height offset using the H1 variable. Maybe the Duet will ignore it?
        3DOesteundefined 1 Reply Last reply Reply Quote 0
          The Duet will generate an error message, but otherwise ignore it.
          • 3DOesteundefined
            3DOeste @timcurtis67
            @timcurtis67 Hi, I'm manually removing the G43H1, I never paid much attention to it since I use it all the time on the machine center and when I occasioanlly don't need it, I edit the file. But now that I actually want to eliminate it I don't know how...
            timcurtis67undefined 1 Reply Last reply Reply Quote 0
              timcurtis67 @3DOeste
              @3doeste said in Autodesk PostProcessor for RRF:
              If you aren't using tool changes in your programs you may be able to eliminate the call function in the post file. I have done it with Mastercam posts but haven't looked into the Autodesk post Porcessor. I will look into it today.
              Do you have the ability to post with a no tool option?
              • 3DOesteundefined
                @timcurtis67 Hi, I was reading the help and apparently you can't dissable tool changes in powermill, it will allways write them with the first trajectory of a NC program. But I'm sure there must be a way to dissable them in the post, it's just my knowledge is limited, I simply edit a fanuc post and dissable eveithing I found that RRF won't interpret. You can write scripts, but I know nothing of programming.
                I don't have the ability to post without a tool in powermill, but I don't know if you can in featurecam or in artcam.
