    XYZ and Extruder on external drivers...
    • CNCModeller
      CNCModeller last edited by
      Hi Folks,
      I'm looking at a semi industrial build and want to use closed loop drivers. I believe I can map the Maestro x and y to external breakouts can I breakout the other axes?
      Many thanks
      Barry M
        The Maestro only has provision for 5 internal and 2 external drivers. If you need more than 2 external, use the Duet WiFi or Duet Ethernet, which supports 5 internal and 7 external. You can map axes and extruders to the drivers any way you like.
