Cura 3.6 problems
I have created a Cura issue reporting this bug.
@burtoogle thanks!Service!
verified that that was the problem...this has worked before but seems to be broken in the plug-in
i have a custom delta printer with duet 2 wifi, i usually use slic3r, but when i started using cura on my ender 3, the top surface finish was better. so when i tried using cura with delta the extrusion was at a very very low rate, i have turned on " relative extrusion" on cura.
Should i make any other changes to the cura of duet settings?
@alexlin how to disable it?
@paul12 disable what?the plug-in...that was something very specific for me since I obviously had turned it on in th elast print in an earlier version. You should be good with th erelative extrusion turned on
