    Homing one axis changes the position of the other axis
    homing piezo precision precision piezo
    631
    • chanders
      chanders last edited by chanders
      Hi guys, I have a peculiar issue. Homing one axis changes the position of the other axis. Example when I home the Y axis (which goes to Y=0), the position for the Z in the DWC changes (if it was 0.3 it may jump to 0.41 etc.)
      What can be causing this? I am using a Precision Piezo with nozzle as probe.
      Here is my firmware version
        Can you post your config.g and homing files?
        chanders 2 Replies Last reply Reply Quote 0
        • chanders
          ; generated by RepRapFirmware Configuration Tool on Sun Mar 11 2018 10:55:11 GMT-0400 (AST)
          M667 S1 ; Select CoreXY mode
          M550 PHypercube Evolution ; Set machine name
          M552 S1 ; Enable network
          M587 S"HomeWiFi" P"xxxxxx" I192.168.0.132 J192.168.1.254 K255.255.255.0 ; Configure access point and IP addresses. You can delete this line once connected
          M586 P0 S1 ; Enable HTTP
          M586 P1 S0 ; Disable FTP
          M586 P2 S0 ; Disable Telnet
          M569 P4 S0 ; Drive 4 goes backwards
          ;M584 X0 Y1 Z2 E4 ; Apply custom drive mapping
          M350 X16 Y16 Z16 E16:16 I1 ; Configure microstepping with interpolation
          M92 X80 Y80 Z800 E418:418 ; Set steps per mm
          M566 X600 Y600 Z20 E120:120 ; Set maximum instantaneous speed changes (mm/min)
          M203 X6000 Y6000 Z300 E1200:1200 ; Set maximum speeds (mm/min)
          M201 X500 Y500 Z300 E250:250 ; Set accelerations (mm/s^2)
          M906 X600 Y600 Z600 E800:800 I30 ; Set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          ;M572 D0 S0.5 ; Pressure advance for Extruder0
          ;M572 D1 S0.5 ; Pressure advance for Extruder1
          M208 X265 Y285 Z270 S0 ; Set axis maxima
          M574 X1 Y1 S3 ; set endstops to use motor stall
          M574 Z1 ; Set endstops controlled by probe
          M558 P7 H5 F120 T6000 ; Set Z probe type to switch, and the dive height, speeds
          G31 P500 X0 Y0 Z-0.1 ; offset and trigger height
          M557 X25:265 Y5:285 S80 ; Define mesh grid
          M376 H10 ; Fade distance
          M304 P377.6 I11.413 D531.8
          M305 P0 T100000 B3950 R4700 H1 L0
          M301 H2 P12.6 I0.584 D35.7
          M305 P2 T100000 B3950 R4700 H1 L0 ; Set thermistor + ADC parameters for heater 1
          M143 H2 S280 ; Set temperature limit for heater 1 to 280C
          M563 P0 D1 H2 ; Define tool 0
          T0 ; Select first tool
          • chanders
            chanders @Phaedrux last edited by
            @phaedrux
            ; homex.g
            ; called to home the X axis
            M400 ; make sure everything has stopped before we make changes
            M913 X60 ; reduce motor current to 50% to prevent belts slipping unfiltered
            M915 P0:1 S3 R0 F0
            G91 ; use relative positioning
            G1 S1 X-325 F3000 ; move to home position
            G1 X25 F2000 ; back off to edge of bed
            G90 ; back to absolute positioning
            M400
            M913 X100 Y100 ; motor currents back to normal
              How bout the other axis homing files?
              chanders 1 Reply Last reply Reply Quote 0
              • chanders
                @phaedrux
                ; homez.g
                ; called to home the Z axis
                ; Drop the bed for travel
                G91 ; Relative positioning
                G1 Z10 F200 S2 ; Lower bed 5mm to ensure it is below the switch trigger height
                ; Move probe into position
                M98 homex.g
                M98 homey.g
                G90 ; absolute positioning
                G1 X145 Y145 F4000 ; Move x and Y axis over to bed center so probe is on top of bed
                ; Set lower speeds for homing
                M566 Z5 ; Set maximum instantaneous speed changes (mm/min) (Jerk)
                M203 Z400 ; Set maximum speeds (mm/min)
                M201 Z100 ; Set maximum accelerations (mm/s^2)
                ; Probe the bed
                M558 A1 F350 ; Set single probing at faster feed rate
                G30 ; Do a single probe to home our Z axis
                ; Set normal speeds again
                M566 Z12 ; Set maximum instantaneous speed changes (mm/min) (Jerk)
                M203 Z300 ; Set maximum speeds (mm/min)
                M201 Z300 ; Set maximum accelerations (mm/s^2)
                • chanders
                  @phaedrux
                  Forum says I'm a newbie so I have to wait one minute before posts 🙄
                    I guess you could have put them all into one post. But I guess that's one way to get your post count up. 😄
                    • chanders
                      @phaedrux
                      https://www.dropbox.com/s/ofst2emogxmefwp/Video Jan 05%2C 6 59 16 PM.mp4?dl=0
                        Are you using mesh grid bed compensation?
                        • chanders
                          @phaedrux
                          Yes I am
                            Try disabling it and see if it behaves the same. Just a hunch but maybe it's not applying correction during homing moves, keeping the z fixed, but it still knows the height based on the height map and displays the actual height.
                            • chanders
                              @phaedrux
                              I believe you are right. Disabling mesh does not change the Z value.
                              Thanks!
