    more endstops
    • madedi123
      madedi123 last edited by
      hi guys
      is it possible to connect mor endstops at the 50 pin header on duet ethernet ?
      • Jacotheron
        Jacotheron last edited by
        If you only need more endstops, you will probably need to make a basic circuit (does not have to be a pcb). The endstop signals are in that header, so looking at where they are located.
        If your endstops are simply micro switches or similar (Normally Open or Normally Closed), you would typically break out the GND to each endstop, and the 2nd wire being the endstop signal (or sometimes the 3.3V is used in stead of the GND).
          See my response to your other post https://forum.duet3d.com/topic/8497/combined-used-duex-5-and-heater-extansion.
