pres. adv, or non lin. extrusion - what to calibrate first?
Hi what are your experience with calibration pressure advance and non linear extrusion? I first calibrated pressure advance and after a while I calibrated non linear extrusion, but then I had regions with underextrusion. So I disabled pressure advance and left the non linear extrusion paramters as they were before and the print results are much better and very good in my opinion.
What do you recommend? Should I also recalibrate pressure advance or isn't it nessesary when the non linear extrusion is calibrate correct?
Best Regards
Cai
How did you calibrate them?
for pressure advance https://forum.duet3d.com/topic/6698/pressure-advance-calibration
for non linear extrusion https://forum.duet3d.com/topic/5588/non-linear-extrusion/22
is there a preference order?
It shouldn't make much different which order you calibrate them in, but if you intend to use nonlinear extrusion then I suggest you calibrate that one first.
