    Z-Probe Capacitive NPN recognized but not stopping Z-homing
    • Kruemel68
      Kruemel68 last edited by
      Hello !
      I need some help
      I connected the Capacitive NPN Probe to E0 Endstop and it is recognized with M119 also E0 enstop LED lights up
      In the duet web control the Z probe is shown with value 1000 when sensor is triggered.:
      M119
      Endstops - X: not stopped, Y: not stopped, Z: at min stop, Z probe: at min stop
      But when homing Z the movement is not stopping when the min stop is triggered.
      My config.g is like this:
      ; Configuration file for RepRap Mendel 3
      ; RepRapPro Ltd
      ; Copy this file to config.g if you have a Mendel 3
      ; If you are updating a config.g that you already have you
      ; may wish to go through it and this file checking what you
      ; want to keep from your old file.
      M111 S0 ; Debug off
      M550 PRepRapPro Mendel 3 ; Machine name (can be anything you like)
      M551 Preprap ; Machine password (currently not used)
      M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0x14 ; MAC Address
      M552 P192.168.1.14 ; IP address
      M553 P255.255.255.0 ; Netmask
      M554 P192.168.1.1 ; Gateway
      M555 P2 ; Set output to look like Marlin
      G21 ; Work in millimetres
      G90 ; Send absolute corrdinates…
      M558 P4 Y0 X0 Z1 I1 ; Use a capacitive NPN Z probe
      M574 X1 Y1 ; set endstop configuration (Y endstop only, at low end, active high)
      G31 Z0.1 P800 ; Set the probe height and threshold (deliberately too high to avoid bed crashes on initial setup)
      M906 X800 Y1000 Z800 E800 ; Set motor currents (mA)
      ;M305 P0 R4700 H0 L0 ; Set the heated bed thermistor series resistor to 4K7
      ;M305 P1 R4700 H0 L0 ; Set the hot end thermistor series resistor to 4K7
      ;M305 P2 R4700 H0 L0 ; Set the hot end thermistor series resistor to 4K7
      M569 P0 S1 ; Reverse the X axis
      M569 P3 S0 ; Reverse the Z axis
      M92 E660:660:660 ; Set extruder steps per mm
      G31 Z0.1 P600 ; Set the probe height and threshold (deliberately too high to avoid bed crashes on initial setup)
      M556 S78 X0 Y0 Z0 ; Put your axis compensation here
      M201 X3000 Y3000 Z150 E500 ; Accelerations (mm/s^2)
      M203 X15000 Y15000 Z100 E3600 ; Maximum speeds (mm/min)
      M566 X200 Y200 Z30 E20 ; Minimum speeds mm/minute
      M208 X-8 S1 ; Set axis minimum (adjust to make X=0 the edge of the bed)
      M208 X214 Y210 ; Set axis maxima (adjust to suit your machine)
      M563 P0 D0 H1 ; Define tool 0
      G10 P0 S-273 R-273 ; Set tool 0 operating and standby temperatures
      homez.g is:
      G91
      G1 Z5 F2000
      G90
      G1 X52 Y22
      G30
      G1 Z0 F1000
      Any idea ?
      Regards,
      Jörn
        What do you have in your homeall.g and homez.g files? If you send a G30 command, does the head stop when the sensor is triggered?
        • Kruemel68
          yes
          with G30 it stops
          homez is above in the thread added.
          homeall is :
          G91
          G1 Z5 F200
          G90
          G1 Y-240 X-300 F2000 S1
          G91
          G1 X3 Y3 F2000
          G1 X-10 Y-10 F200 S1
          G90
          G1 X60 Y0 F6000
          G30
          G1 Z5
          as soon i am moving the head to another position the z probe is no longer stopping the head…...
          using G30 in the console it works
          when used in script it isn't
