    Can't upload .gcode, getting an error
    • briskspiritundefined
      briskspirit
      Hi.
      After some time I can't upload big .gcode files through web(one file is ~4.5Mb and other is 12Mb) Checked my SD card - everything is ok(original that was with Duet Wifi)
      WiFi Server Version: 1.21
      Web Interface Version: 1.22.6
      • Wyvernundefined
        Wyvern
        Try updating to new web control.
        I was having issues myself and had to reset the machine to get the file transfers back up to speed, since the update I haven't had an issue.
        Also run a M122 to see how good your WIFI connection is.
        • oliofundefined
          oliof
          Thus improved greatly for me when I updated to the v1.22 wifi Server
            Also, send M39 to check the cluster size on the SD card. It i's less than 32kb, then get a new SD card, format it to 32kb or 64kb clusters, copy the old card to the new cared, then use the new one.
            briskspiritundefined 1 Reply Last reply Reply Quote 0
              briskspirit @dc42
              @dc42 That card was with Duet and worked fine. New web interface helped to solve this error.
