    Start Gcode
    • jamesadoty
      jamesadoty last edited by
      Hi all:
      With your generous help I have my Duet 2 Wifi working (Mostly) on my Tronxy X5SA 3D printer.
      I'm running my first new part now.
      I need to tweak my start code a bit so that it auto lowers my print bed before heating the bed and nozzle. Also my bed leveling isn't working.
      I've set up bed leveling in bed.g and tried to call it up from my start gcode. Here's a snippet.
      I'm using Simplify3D.
      Home all did work though.
      Any ideas?
      G90
      M82
      M106 S0
      M140 S60
      M190 S60
      M104 S190 T0
      M109 S190 T0
      M98 P/MACROS/HOMEALL.G
      ;G28 ;Home
      M98 P/MACROS/BED.G
      ;G29 ;auto level
      G1 Z15.0 F6000 ;Move the platform down 15mm
      ;Prime the extruder
      G92 E0
      G1 F200 E3
      G92 E0
      • jamesadoty
        Found the problem, and it was my mistake.
        I didn't need the path to the macros. Just:
        M98 P<macro_name>
        I just restarted a print which filed, and the start gcode worked perfectly.
          You don't even need to use M98 to call those macros. Bed.g in the sys folder is called by G32, and homeall.g in the sys folder is called by G28.
          jamesadoty 1 Reply Last reply Reply Quote 0
          • jamesadoty
            jamesadoty @Phaedrux last edited by
            @phaedrux
            Sweet. I'll make those changes.
            I'm on my second print now.
            My first print using PLA was successful but very stringy.
            I was printing with the bed at 60c and the nozzle at 190c. Typical cooling fan settings, retraction distance of 1mm.
            My printer has a bowden style extruder so on the second print I've set retraction to 2mm to see if that helps, and raised the nozzle temperature to 200c.
            I need to tune up my nozzle heating, it's slower than the software likes and often errors out due to taking too long to reach set temperature. I'll do that after the current print, likely not until tomorrow though since I've been working on this with only a few breaks for over ten hours today.
