    Fans and touchscreen won't work
    • justdatguy
      justdatguy last edited by
      I setup my first duet 2 wifi board today and I've gotten just about everything to work except for the fans and the touchscreen. The fans don't move at all, not even if I put them into the always-on connectors. The always-on connectors output about .2 volts according to my multimeter. The touchscreen itself is completely functional, but it can't control the printer. Nothing happens when I use the touchscreen. I'm more concerned about the fans than the touchscreen
      • justdatguy
        I got the fans working. I didn't realize I needed to install that jumper. Touchscreen is still completely useless though.
          Which touch screen? What does it do? How is it wired?
          justdatguy 1 Reply Last reply Reply Quote 0
          • justdatguy
            justdatguy @Phaedrux last edited by
            @phaedrux It's the v3 4.3 paneldue one. It's wired using the 4 wires. The screen functions perfectly fine, but it just doesn't communicate with the duet at all.
            • aidar
              aidar last edited by
              Hi
              Please check that baud rate is configured correctly on both, duet and PanelDue.
              You can add this line to config.g file : M575 P1 B57600 S1 to configure duet and check baud rate on Paneldue in settings screen.
