    Prevent Multiple Retracts and Unretracts
    • Eddiie
      Eddiie last edited by
      Is it possible, or does it already do this? To have the firmware ignore multiple G10 commands without a G11 and vice-versa ignore multiple G11's without a G10?
      Retract Example:
      G10 check for flag, if flag is high, ignore G10 command, otherwise set a flag to 1 and retract.
      G11 reset flag and unretract.
      this might get complicated with multiple tools.. ?
      I am noticing back to back G10's in my GCode
      • fma
        fma last edited by
        The firmware already ignores multiples G10 and multiple G11...
        • deckingman
          deckingman @Eddiie last edited by deckingman
          @eddiie said in Prevent Multiple Retracts and Unretracts:
          Retract Example:
          Yes, the firmware will never do multiple retracts or un-retracts. So if your gcode file contains multiple G10 commands, only the first will be acted on. Subsequent G10 commands will be ignored until a G11 command is sent. Likewise only the first G11 unretract will be acted on and any others will be ignored until a G10 command is sent.
          Edit sorry @fma - looks like we were typing at the same time.
          Edit 2. This behaviour also applies if you try and send multiple G10 or G11 commands via the console.
          • Eddiie
            That is great news! Thanks guys.
