    Pressure advance
    • bret4
      bret4 last edited by
      I wonder if you have to first turn on pressure advance in config.g before you can use it in say start gcode in a slicer?
      I would like to change pressure advance settings for different filaments and not have to change config.g each time. But wonder if it will work if not setup in config.g first.
      • timcurtis67
        timcurtis67 last edited by
        You can adjust or turn pressure advance on and off at anytime. Even "on the fly" while printing a part.
        Adjust it through the DWC or if you have a paneldue adjust it in console.
        It can be added in a script to your slicer as well.
        • timcurtis67
          Also see https://duet3d.dozuki.com/Wiki/Filaments to add the different pressure advance settings to each filament file you build.
          • bret4
            So if I don't have any reference to pressure advance in config.g, it can be turned on with the m code at anytime.
            I think I saw something about Kepler pressure advance that said they had to turn it on in firmware to activate it, so that made me wonder if reprap worked the same way.
            deckingman dc42 2 Replies Last reply Reply Quote 0
            • deckingman
              deckingman @bret4 last edited by
              @bret4 said in Pressure advance:
              So if I don't have any reference to pressure advance in config.g, it can be turned on with the m code at anytime. ...........................
              Yes - and that also applies to all other G and M commands - accelerations, retractions, you name it - (very useful for tuning).
                dc42 administrators @bret4 last edited by
                All features of RRF except a very few experimental features are included in the standard firmware, and all can be activated at any time. There are rules for a few commands about what order commands must be run it, but that's all.
                • bret4
                  Thank you for all the answers.
