    Faulty smart Effector
    • boldnuts
      boldnuts last edited by
      My smart Effector has gone faulty out of the blue as there is no power to the hotend but the led does light's up, on doing a continuity check there is an open circuit between the hotend negative input H1 and the heater negative output H1 on the pcb and I can see no damage at all, is there a circuit diagram so that I could repair this?. Would soldering a wire directly between them be ok.
      • oliof
        oliof last edited by
        Are You looking for
        https://github.com/T3P3/SmartEffector/blob/master/SmartEffector/SmartEffector_v1.3/SmartEffector_Schematic_v1.3.pdf ?
        <>Creality CR-20 IDEX Duet3 mini 5+<>RatRig V-Minion SKR RRF 1.1<>
        • boldnuts
          Thanks, I have now managed to repair it, it looks like the though plating on the heater output connector H1 had failed, re-soldered it and fitted a small wire between both input and out connectors, all working now
            I'm glad you managed to fix it. We've heard of this sort of thing happening at least once before, so we did a design revision a while ago to duplicate the heater traces on both sides of the board. The copper thickness is only about 0.5oz so that the resistance of the strain gauge traces is high enough, and that makes the traces less good at carrying high currents, especially where they connect to the through holes. I'm guessing that you use a fairly high powered 12V heater.
            • boldnuts
              Yes that's correct dc42, I am using the E3D 24V 40W heater cart,https://e3d-online.com/standard-heater-cartridge, is this ok?
                dc42 administrators @boldnuts last edited by
                @boldnuts said in Faulty smart Effector:
                40W is on the high side, but as you are using 24V power I'm surprised there was a problem.
