    My Maestro Menu Files are now on github
    50
    7.0k
    • 3dmntbighkerundefined
      3dmntbighker
      Anybody see my suggestion that the file menu filter out file system meta data files like with a "._" prefix? Or they they get outright deleted.
      Scratch built CoreXY with Maestro
      Heavily modified Ender 3 with Maestro
      MPCNC work in progress with Duet WiFi
      • mudcruzrundefined
        mudcruzr
        v1.5 now up on github:
        https://github.com/mudcruzr/Duet-Maestro-12864-Menu-Files/releases
        Release note:
        Added a new control menu (CTRL), accessed from the main screen. it allows the following:
        COOLDOWN (turns off bed and nozzle heaters and the parts cooling fan)
        MOTORS OFF (releases all motors N.B. also "unhomes" all axes)
        REBOOT MAESTRO
        RUN MESH COMP (homes all axes, heats bed to 50C, heats nozzle to 180C, runs mesh compensation and then turns heaters off)
          dc42 administrators @3dmntbighker
          @3dmntbighker said in My Maestro Menu Files are now on github:
          If you can't stop your Mac putting those files on the SD card, I suggest you delete them. You can do that on the Display Editor page.
          3dmntbighkerundefined 1 Reply Last reply Reply Quote 0
            3dmntbighker @dc42
            @dc42 said in My Maestro Menu Files are now on github:
            Actually, the "._" files are Windows. The Mac uses ".DS_Store" files for metadata. So likely I inherited these from someplace else? My proposal was to not display them since everyone is so likely to end up with them at some point.
              The firmware already suppresses returning filenames that start with '.' and I just tested that it still works. So I am puzzled that you are seeing them. Which firmware version are you using?
              mudcruzrundefined 1 Reply Last reply Reply Quote 0
              • mudcruzrundefined
                mudcruzr @dc42
                @dc42 Files whose names begin with "." are suppressed in DWC as you have confirmed, but are displayed by the Maestro's menu system "files" command on the 12864 lcd. I have just tested and confirmed this. (Latest firmware, latest DWC etc.)
                3dmntbighkerundefined dc42undefined 2 Replies Last reply Reply Quote 1
                  3dmntbighker @mudcruzr
                  @mudcruzr said in My Maestro Menu Files are now on github:
                  Yep, that's what I'm sayin bro 😉
                    dc42 administrators @mudcruzr
                    Now I understand! I thought you were saying that files beginning with '.' in the /menu folder were showing up in DWC.
                    I've made a code change to hide filenames beginning with '.' in the 12864 files display. This will be released in the 2.03beta firmware.
                    mudcruzrundefined 3dmntbighkerundefined 2 Replies Last reply Reply Quote 0
                    • mudcruzrundefined
                      mudcruzr @dc42
                      @dc42 Many thanks.
                        3dmntbighker @dc42
                        Sweet!!! 🙂
                        • mudcruzrundefined
                          mudcruzr
                          v1.6 is now on github,
                          https://github.com/mudcruzr/Duet-Maestro-12864-Menu-Files/releases/tag/v1.6
                          here are the release notes:
                          As I no longer need a blank line at the bottom of the main page for M117 messages (Now using M291 messages). I was able to use that real estate to give the existing layout some extra elbow room in the vertical direction. If you do have any M117 message strings (e.g. M117 "Print Started" in your slicer's start G code section) you should change them to use M291 (e.g. M291 P"Print Started") if you want them to display on the 12864
                          Additionally, I was made aware that without a license assigned to this project, technically no-one should use it. I think that the unlicense is the most liberal available and the most appropriate for the intent behind providing these menu files.
                          enjoy
                          Vetiundefined 1 Reply Last reply Reply Quote 1
                          • mudcruzrundefined
                            mudcruzr
                            v1.7 now on Github
                            https://github.com/mudcruzr/Duet-Maestro-12864-Menu-Files/releases/tag/v1.7
                            Release notes:
                            After a recent print went wrong and crashed the BLTouch bending the pin, I realised I had no way of manipulating the probe while I was standing at the printer. I've added the ability to extend, retract, test, and reset the probe from this new menu. It is accessed from the CTRL (Control) menu.
                            • Vetiundefined
                              Veti @mudcruzr
                              @mudcruzr
                              Regarding the license. You might consider the WTFPL
                              • mudcruzrundefined
                                mudcruzr @Veti
                                @veti lol, if I'd seen that before I attached the unlicense, I might have.
                                • mudcruzrundefined
                                  mudcruzr
                                  I've updated a couple of the 12864 menu files to cope with the changes in 2.03RC1
                                  As usual they are in https://github.com/mudcruzr/Duet-Maestro-12864-Menu-Files
                                  2 Files required updates to cope with the changes in 2.03RC1
                                  The new files are main_for_203RC1 and heat_for_203RC1
                                  Upload the 2 new files, rename the existing heat and main to something like heat_backup and main_backup then rename the 2 new files to heat and main respectively.
                                  Note these files are ONLY for using with 2.03RC1
                                  • sinned6915undefined
                                    sinned6915
                                    mudcruzr-
                                    THANK YOU for making the files available!
                                    I am using them on LPC1768 port on a ReArm with RRD full graphic LCD.
                                    No network as of yet, and Octoprint is not playing nice with LPC port. LCD is the only way to print.
                                    I changed leveling menu because I don't use BLTouch, but all of the others seem to work well.
                                    Thanks again for your work and for sharing.
                                    Dennis
                                    • A Former User?
                                      A Former User
                                      Thanks for sharing, this is great.
                                      I wonder would it it not be a good resource to link to from the wiki?
                                      https://duet3d.dozuki.com/Wiki/Duet_2_Maestro_12864_display_menu_system
                                      • mudcruzrundefined
                                        mudcruzr
                                        I wouldn't have an issue with that but I guess it'd be up to @dc42
                                          Link added!
                                            sinned6915
                                            Is there a 'built in' Maestro function to turn the main power off/on? I want to toggle the PS_ON pin via M80/M81.
                                            I am looking to add this to the main menu as a button. All I can come up with so was is defining 2 buttons, one "On" and one "Off".
                                            I can not figure out how to toggle a single button as of yet- 2 img files, one for on, one for off. when one state is enabled, the other is an option.
