    Bed leveling using dual z motors
    • FlyingScotundefined
      FlyingScot
      As the bed was losing its position on power off due to the weight causing it to run down the leadscrews I have re-confured the z axis to use independent z motors.
      I am using the E1 output for the second motor.
      The problem is that the motors are not moving the same distance as each other.
      Thankfully I removed the bed before testing.
      I think it must be due to settings of the E1 output but have been unable to figure out what
      Firmware is v2.01
      Can anyone advise where I am going wrong?
      Arthur
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M555 P1 ; Set firmware compatibility to look like RepRapFirmare
      M564 H0 ; Limit axis
      M572 D0 S0.18 ; Set extruder pressure advance.
      M667 S1 ; Select CoreXY mode
      M584 X0 Y1 Z2:4 ; 2 Z motors connected to driver outputs 2 & 4
      M671 X-80:480 Y200:200 ; Z lead screws are at (-80,200) (480,200)
      M569 P4 S0 ; Drive 4 goes backwards
      M350 X128 Y128 Z128 E16 I0 ; Configure microstepping without interpolation
      M92 X800 Y800 Z3200 E95 ; Set steps per mm
      M203 X12000 Y12000 Z1200 E3000 ; Set maximum speeds (mm/min)
      M201 X1000 Y1000 Z1000 E5000 ; Set accelerations (mm/s^2)
      M906 X855 Y855 Z1200 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X400 Y400 Z450 S0 ; Set axis maxima
      M574 X1 Y1 S0 ; Set active low endstops
      • MikeInNsundefined
        MikeInNs
        Hi FlyingScot, can you try adjusting your M584 to include your extruder as well:
        M584 X0 Y1 Z2:4 E3; 2 Z motors connected to driver outputs 2 & 4
          FlyingScot
          Thaks for your quick reply Mike that has sorted it.
          I knew it would be something simple but just could not see it.
          Regards
          Arthur
          • AS-3D Druckundefined
            AS-3D Druck
            So you can use both of you're Leadscrews (z-Motors) to level you're Bed?
            Cause i've got the same issue that my Bed goes down a little bit over time.
            Could you explain how the Meshbedleveling and other Stuff work with that?
            Best regards
            AS-3D Druck / Andre
