Mesh Grid - Result is not ok
  • Hi
    i have a AM8 with Duet Wifi with Mini Ir probe
    Now i would install Auto bed leveling but the bed seems not to be linear
    config.g
    ; generated by RepRapFirmware Configuration Tool v2 on Sun Jan 13 2019 14:56:09 GMT+0100 (Mitteleuropäische Normalzeit)
    M550 P"AM8" ; Set machine name
    M552 S1 ; Enable network
    M587 S"WLAN-363335" P"luigello20101984" ; Configure access point. You can delete this line once connected
    M586 P0 S1 ; Enable HTTP
    M586 P1 S0 ; Disable FTP
    M586 P2 S0 ; Disable Telnet
    M92 X100.00 Y100.00 Z400.00 E100.00 ; Set steps per mm
    M566 X600.00 Y600.00 Z18.00 E300.00 ; Set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z180.00 E6000.00 ; Set maximum speeds (mm/min)
    M201 X1500.00 Y1500.00 Z100.00 E10000.00 ; Set accelerations (mm/s^2)
    M906 X500.00 Y500.00 Z500.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X-33 Y-10 Z0 S1 ; Set axis minima
    M208 X220 Y220 Z240 S0 ; Set axis maxima
    M574 X1 Y1 S0 ; Set active low and disabled endstops
    M558 P1 H4 F120 T6000 ; Set Z probe type to modulated and the dive height + speeds
    G31 P500 X0 Y0 Z1.125 ; Set Z probe trigger value, offset and trigger height
    M557 X20:200 Y20:200 S40 ; Define mesh grid
    M305 P0 T100000 B4388 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 0
    M143 H0 S130 ; Set temperature limit for heater 0 to 130C
    M305 P1 T100000 B4388 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
    M143 H1 S275 ; Set temperature limit for heater 1 to 275C
    M563 P0 D0 H1 ; Define tool 0
    T0 ; Select first tool
    bed.g
    ; bed.g
    G29 ; probe the bed and enable compensation
    what i can do to solve it ?
    thanks an dsorry for my bad english
    Does that machine have 2 Z motors, one at each end of the Z axis? If so then it looks like they have got out of sync. You can sync them automatically, see https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors.
  • Yes it have 2 Z Motors
    i will check your link
    thanks
  • are you sure your x-axis height (to the bed) was equal left and right side, before you started measuring the bed? For a certain X position the z height is the same for the whole length of your Y...so it looks like your x-axis wasn't leveled.
  • @lui2004 for bed levelling you need to use 2 drivers for you 2 z motors
  • i dont understand the example from the wiki
    can you give me some help
    thank you
  • New Automatic Calibration Results
    what i can do to make it better without to buy new hardware is it possible ?
    thanks
    1. It looks like you had a large probing error at one particular point (the red one). Is it repeatable? Is there anything special about that point?
    2. Which firmware version are you using?
  • No nothing particular on this point
    Every mesh grid The same point
    I use the last Firmware 2.02
    I have read that i can use The E1 for a second z motor Drive? Is it correct ? So i can use The Wiki link Fromm dc42 ?
  • This is my 3dPrinter
  • Nothing?
    I dont be forward still same Problem.
  • so i have made some changed
    2 indepedet motors for Z ( ZA and E1 )
    config.g
    M569 P4 S0 ; Drive 4 goes backwards
    M584 X0 Y1 Z2:4 ; two Z motors connected to driver outputs Z and E1
    M671 X-20:220 Y0:0 S0.5 ; leadscrews at left and right of X axis
    M208 X-33:205 Y0:200 ; X carriage moves from -5 to 205, Y bed goes from 0 to 200
    ;M208 X-33 Y-10 Z0 S1 ; Set axis minima
    G31 P500 X0 Y0 Z1.697 ; Set Z probe trigger value, offset and trigger height
    bed.g
    ; bed.g
    ;M561 ; clear any bed transform
    ;G29 ; probe the bed and enable compensation
    G28 ; home
    M401 ; deploy Z probe (omit if using bltouch)
    G30 P0 X20 Y100 Z-99999 ; probe near a leadscrew, half way along Y axis
    G30 P1 X180 Y100 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
    M402 ; retract probe (omit if using bltouch)
    thats my actual height map
  • But here you have only performed bed level with the leads crews. Not any mesh, i.e. G29. At least I don't see that in bed.g file.
    There is something seriously wrong.... Why are the x and y coords of you sample points not in a grid? Isn't that that the plot straight from above?it must the perspective...
    Why do you deploy for the ir sensor?
  • Hi
    Thanks for your answer
    Also i have to add this code in bed.g
    ; mesh probe
    G29 S0
    My english is not The best can you give a advise
  • i think i found the problem i have insert bed leveling with mesh
    now i have only mesh
    20.00,200.00,20.00,200.00,-1.00,40.00,40.00,5,5
    0.015, 0.398, 0.325, 0.287, 0.205
    0.322, 0.352, -0.173, 0.335, 0.265
    0.342, 0.357, 0.882, 0.337, 0.280
    0.305, 0.232, 0.317, 0.285, 0.305
    0.168, 0.355, 0.245, 0.232, 0.385
    my new config.g
    G31 P500 X0 Y0 Z2.180 ; Set Z probe trigger value, offset and trigger height
    bed.g:
    ; bed.g
    My New Result Mesh:
  • Moderator
    Does your bed surface have a bit of a reflectiveness to it? Can you try probing your bed with a piece of plain white printer paper on it? I'm thinking maybe the IR probe isn't getting a good reading from your bed surface.
  • I have The buildtak Vertex
    I will Test it tommorow
    If its reflectiveness what i can use to probing?
  • Moderator
    You can try adding an A and S parameter to your M558 command to try and increase probing consistency.
    M558 A10 S0.003
    this will cause the probe to probe up to 10 times if the consistency of two consecutive probe results are within 0.003mm of each other.
  • Like this
    M558 P1 H4 F120 T6000 A10 S0.003
  • Moderator
    @lui2004 Yes
  • Ok i i will test now
  • with white printer paper i got
    Error: Z probe already triggered before probing move started
    with M558 P1 H4 F120 T6000 A10 S0.003
    i got
    0.003, 0.548, 0.559, 0.647, 0.682
    0.476, 0.589, 0.143, 0.761, 0.788
    0.573, 0.633, 1.234, 0.772, 0.788
    0.636, 0.613, 0.753, 0.771, 0.841
    0.603, 0.835, 0.740, 0.761, 0.978
  • Moderator
    @lui2004 said in Mesh Grid - Result is not ok:
    Try increasing your dive height perhaps? I'm not super familiar with the behaviour of the IR probes.
    I can't tell from the number grid if that's an improvement or not. Does the image look more consistent?
  • Is there any direct lighting around your machine? is your machine around any natural (outside) lighting? I have read that florescent lighting and possibly LED lighting can cause issues.
  • @phaedrux Hi
    no the image is still the same nothing change
    hope everybody can help me to solve
