    Ezabl mini direct connect z probe from th3d
    • Government_Baconundefined
      Government_Bacon
      Im having touble with my ezabl. keeps saying trigger before probing.
        You will need to tell us how you have connected it to your Duet, and how you have configured it in your M558 command in config.g. Also some information on what type of output it provides.
          Government_Bacon
          I have it connected to the probe in and ground and the M558 P5 I1
            Perhaps it doesn't need the i1 part? Test the probe as described at https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe.
            • TheRulesLawyerundefined
              TheRulesLawyer
              I just hooked mine up and if the probe in and ground were reversed, it never triggered. Can you see it go from 0 to 1000 in the UI? If so you need to add/remove the I1 modifier from M558. If not, you probably have the ground and Signal wires swapped. Polarity matters here.
              • falcarundefined
                falcar
                I have this working on my machine:
                M558 I1 P5 H5 F120 T6000
