Slow Duet WiFi
  • Hi,
    Since a week the webinterface of the Duet2 Wifi board loads very slow:
    The dwc.js file takes 25 seconds to load.
    Also sending movement commands seem to be slow:
    I've replaced the SD card with a another one and sadly the same result.
    Also the status update sometimes seem to take 2 seconds:
    I've updated the firmware to the latest version:
    Here's the output of the M112 command:
    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet WiFi 1.02 or later
    Board ID: 08DGM-917NK-F2MS4-7JKD6-3SN6P-9GUNG
    Used output buffers: 1 of 20 (8 max)
    Static ram: 25524
    Dynamic ram: 98524 of which 0 recycled
    Exception stack ram used: 280
    Never used ram: 6744
    Tasks: NETWORK(ready,648) HEAT(blocked,1232) MAIN(running,3812) IDLE(ready,200)
    Owned mutexes:
    Last reset 00:01:42 ago, cause: software
    Last software reset at 2019-01-26 19:55, reason: User, spinning module GCodes, available RAM 6744 bytes (slot 2)
    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
    Error status: 0
    Free file entries: 10
    MCU temperature: min 28.8, current 29.3, max 29.5
    Supply voltage: min 19.3, current 19.4, max 19.5, under voltage events: 0, over voltage events: 0, power good: yes
    Date/time: 2019-01-26 19:57:19
    Cache data hit count 376775670
    Slowest loop: 2.47ms; fastest: 0.07ms
    I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
    Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
    Scheduled moves: 0, completed moves: 0
    Bed compensation in use: none
    Segments left: 0
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 0
    serial is idle in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 22.73ms; fastest: 0.00ms
    HTTP sessions: 1 of 8
    • WiFi -
      Network state is running
      WiFi firmware version 1.22
      WiFi MAC address b4:e6:2d:53:15:de
      WiFi Vcc 3.46, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 27552
      WiFi IP address 192.168.11.179
      WiFi signal strength -53dBm, reconnections 0, sleep mode modem
    When I upload a file I get a speed of 350 KiB/s.
    Any help would be welcome!
    Kind regards,
    Frederik
  • You could try DWC 2.0 to see if it works better.
  • Thanks for the suggestion but no luck 60 seconds till the file loads.
    Try rebooting your router and PC, if you haven't already.
  • @dc42 Thx, that fixed my problem. Any idea what could be the cause of this? Many thx.
    @frederikv said in Slow Duet WiFi:
    I've no idea, I just know that it works for some people sometimes.
