    What is Jerk setting called in RepRap?
    1.6k
    • Steve Lynchundefined
      Steve Lynch
      Hi Guys! I seem to be getting differing opinions on facebook. In the duet config.G, where do I adjust Jerk settings? What exactly is it called in config? I see nothing called "Jerk" as I normally see in Marlin. What parameter controls jerk in reprap? Thanks!
      • burtoogleundefined
        burtoogle
        M566
        • R3playundefined
          R3play
          Example:
          M566 X900.00 Y900.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
          Edit:
          Beware that these changes are in mm/min!
          • wilrikerundefined
            wilriker
            Also added in either RRF 2.01 or 2.02 is (the still undocumented) M205 which sets the jerk/instant deviation in mm/s as it is done in Marlin based firmware.
            Manuel
            My Tool Collection
              dc42 administrators @wilriker
              @wilriker said in What is Jerk setting called in RepRap?:
              Now documented. M205 is supported from firmware 2.02. Only the XYZ and other axis parameters are supported, other parameters will be ignored.
