Ramps Basic Display With Duet?
Is it possible to connect a ramps basic display to the duet board via the CONN_LCD output connector? I want to see if anybody else has had this work before I attempt it just in case it hurts my board.
Thanks for the help, Ethan
@eth7an RAMPS displays are not supported on the DuetWifi. You would need to add level convertors and the firmware doesn't support them.
the short answer: no
https://forum.duet3d.com/topic/8842/display-support-lcd-12864/5
