    Nozzle stops at perimeter change
    1.2k
    • Royceundefined
      Royce
      Hi folks,
      As I'm currently analyzing my blobbing problem, I noticed the following:
      When retracting at layer change, the nozzle pushed quite a big blob at the start or the first (inner) perimeter.
      Additionally, the nozzle stops for a split second when it changes to the next perimeter(s) which also results in additional blobbing.
      Does anyone have a clue why this stopping occurs?
      Link to S3D profile and Duet config:
      https://drive.google.com/drive/folders/1Km_6ZQwyBDyLP2Ud__PldtW7bxEX-NcE?fbclid=IwAR3nCLb5PsGNBp8A_SwU41jG-jFciY0TJX-w4Bt0CYU6mMRsYJOXp-UB6xk
      Thanks in advance,
      Paul
        It looks like you're retracting 12mm of filament at 10mm/s which is going to cause a noticeable pause on layer change. At least that's what I gathered from the factory file plain text since I don't have S3D. But the behaviour you describe would be consistent with slow retraction or slow layer change.
        I suggest tuning your retraction to see if you really need 12mm and increasing the retraction speed.
        • Royceundefined
          Royce
          I'm retracting 6 or 6.5mm at 60mm/s.
          Dont know where these numbers come from 🙂
          Update:
          The short stop is also present on an object sliced with Slic3r.
            Are you using coasting or wipe on retract?
            Pressure advance?
            Firmware version?
            Royceundefined 1 Reply Last reply Reply Quote 0
            • Royceundefined
              Royce @Phaedrux
              @phaedrux
              No wipe or coast is used (wipe + coast gave me worse results).
              PA is disabled, Firmware version 1.21
                It will be easier for us to work out what is going wrong if you share a GCode file that exhibits the symptom.
                • Royceundefined
                  Royce @dc42
                  Good idea.
                  Gcode file added to the Google Drive link from above
                    dc42 administrators @Royce
                    @royce said in Nozzle stops at perimeter change:
                    Retracting 6.5mm of filament with speed 60mm/sec and acceleration/deceleration 2000mm/sec^2 will take 0.14sec. So will re-priming. Is this the "split second" that you observe?
                    • Royceundefined
                      Royce
                      Well, when changing perimeter lanes (from inner to mid to outer), there is no retraction. It just changes the lanes.
                      So I dont think the stop has something to so with the retraction.
                        I'm sorry, I misunderstood. Here is a sample perimeter change from your file:
                        G1 X168.762 Y144.337 E0.0357
                        ; feature outer perimeter
                        G1 X169.050 Y143.953 F7200
                        G1 X169.534 Y144.346 E0.0231 F1800
                        It should complete the last extrusion of the inner perimeter (coming to a stop at the end of the move), execute the ~0.5mm travel move, then start the new perimeter. The time it takes to do all that will depend on your acceleration settings. If you are using a Bowden extruder and no pressure advance, then there will be some over-extrusion at the end of the inner perimeter, some oozing during the short travel move, and perhaps a little under-extrusion at the start of the outer perimeter. The fix for that is to use pressure advance.
                        • Royceundefined
                          Royce
                          That's good to know.
                          So I need to dig into the PA feature a little more, I didnt use it so far.
                          Any point to start?
                            For a non-Bowden extruder, try 0.05. For a Bowden extruder, try 0.2. For best results, search this forum for threads on calibrating pressure advance.
                            Royceundefined 1 Reply Last reply Reply Quote 1
                            • Royceundefined
                              Royce
                              Thank you, I'll read it up 🙂
                              Very much appreciated!
                              • Royceundefined
                                Royce @dc42
                                Do I need to set M572 in the config or in the slicer's start code?
                                  It doesn't matter. I set it in config.g. If you find that you get best results using different values for different filaments, you can put it in the slicer start GCode instead.
                                  You can change it on-the-fly by sending the M572 D0 Snn command from the GCode Console of DWC, or over USB, or from PanelDue. It takes a few seconds for the new value to take effect.
                                  Note, if you use high values of pressure advance (e.g. above 0.4) then you may need to reduce retraction, to avoid over-retraction.
