Bed calibration error. 4 points requested, only 3 points probed.
So I have 4 independent z leadscrews set up. I have configured the config.g and bed.g files appropriately. When I run G32 I watch it probe 4 points on the bed, however I get an error in the g-code console telling me it requested 4 probe points but only received 3.
Here is my bed.g file
; bed.g ; called to perform automatic bed compensation via G32 ; ; generated by RepRapFirmware Configuration Tool v2 on Fri Nov 16 2018 19:13:03 GMT-0500 (Eastern Standard Time) M561 ; clear any bed transform G28 ; home G30 P0 X51 Y15 Z-99999 ; probe near a leadscrew G30 P0 X51 Y280 Z-99999 ; probe near a leadscrew G30 P1 X300 Y280 Z-99999 ; probe near a leadscrew G30 P2 X300 Y15 Z-99999 S4 ; probe near a leadscrew and calibrate 5 motors
and here is my config. g
; Configuration file for Duet WiFi (firmware version 1.21) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2 on Fri Nov 16 2018 19:13:03 GMT-0500 (Eastern Standard Time) ; General preferences G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves M667 S1 ; Select CoreXY mode ; Network M550 P"CoreXY" ; Set machine name M552 S1 ; Enable network ;*** Access point is configured manually via M587 M586 P0 S1 ; Enable HTTP M586 P1 S0 ; Disable FTP M586 P2 S0 ; Disable Telnet ; Drives M569 P0 S1 ; Drive 0 goes backwards M569 P1 S1 ; Drive 1 goes backwards M569 P3 S1 ; Drive 3 goes backwards M569 P5 S0 ; Drive 5 goes forwards M569 P6 S0 ; Drive 6 goes forwards M569 P7 S0 ; Drive 7 goes forwards M569 P8 S0 ; Drive 8 goes forwards M350 X16 Y16 Z16 E16 I1 ; Configure microstepping with interpolation M92 X80.00 Y80.00 Z2560.00 E96.00 ; Set steps per mm M566 X900.00 Y900.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min) M203 X3000.00 Y3000.00 Z600.00 E1200.00 ; Set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00 ; Set accelerations (mm/s^2) M906 X1300.00 Y1300.00 Z1000.00 E1000.00 I30 ; Set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; Set axis minima M208 X300 Y380 Z310 S0 ; Set axis maxima ; Endstops M574 X1 Y1 S1 ; Set active high endstops ; Z-Probe M574 Z1 S2 ; Set endstops controlled by probe M558 P1 H5 F120 T6000 ; Set Z probe type to modulated and the dive height + speeds G31 P500 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height M557 X15:290 Y15:370 S20 ; Define mesh grid ; Heaters M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0 M143 H0 S90 ; Set temperature limit for heater 0 to 90C M305 P1 T100000 B4388 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1 M143 H1 S280 ; Set temperature limit for heater 1 to 280C ; Fans M106 P0 S1 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on ; Tools M563 P0 S"Extruder 0" D0 H1 ; Define tool 0 G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C ; Automatic saving after power loss is not enabled ; Custom settings are not configured M584 X0 Y1 Z5:6:7:8 ; four Z motors connected to driver outputs 5, 6, 7 and 8 M671 X51:51:347:347 Y-68:393:393:-68 S1 ; leadscrews at front left, rear left rear right and front right ; Miscellaneous M591 D0 P5 C3 R40:120 E3.0 ; Duet3D laser sensor for extruder drive 0 is connected to endstop input 3 (E0), tolerance 40 to 120%, 3mm comparison length T0 ; Select first tool
I'm sure I'm missing something somewhere, but I can visually see it probe 4 points. Maybe I need to change the S parameter for maximum correction?
@surgikill You're first and second probe points have the same P#.
@Stephen6309 Wow I'm a dipshit. Thanks.
