Guide to calibrate axis steps for mm
  • Hi,
    since some days, what changed config.g, i am having issues... layer displacements, first layers are ok, but when reach layer 25/30 aprox, there is displacement betewn layers.... until yesterday , i think was a mechanical problem.... but now, i am not sure, why.... because observing displaced layer, i hear like nozzle slash the inferior layer....
    As if each time a layer came up, I went up a little less, I guess ...
    Is there a method to check the steps for mm in a delta? I have see methods, for cartesian.... but i am not sure, if this methods can be used in a delta
  • can you give some more information on your machine?
    proper geometry for a delta is very important.
    see http://boim.com/DeltaUtil/CalDoc/Calibration.html
