    driving 24v 4A 6Ohm solenoids, selection of flyback diode
    664
    • NitroFreak
      NitroFreak last edited by
      I wanted to quickly ask,
      I wanted to drive a Solenoid (6 Ohm, rated for 12v and 2A, Duty cycle 10%) off of the expansion board on the Duet.
      It is only actuated momentarily with 24v for switching the hotends, so i think the duty cycle with the higher current should be fine.
      https://www.youtube.com/watch?v=fYOE01SzS9Q
      My question is if one of those Diodes would be fine?
      https://www.reichelt.de/gleichrichterdiode-1000-v-15-a-axial-px-1500m-dio-p217011.html?&trstct=pol_8
      https://www.reichelt.de/gleichrichterdiode-1000-v-12-a-to-220ac-byt-12p-1000-p6356.html?&trstct=pol_7
      And the mosfets would be those
      mosfet board 25A
      Thank you
      Max
        Either of those diodes will be more than adequate. The mosfet board will it be suitable if it will work from a 3.3V control signal.
        Alternatively, if the E1 heater output on your Duet is spare, connect it to that. You still need the flyback diode.
        NitroFreak 1 Reply Last reply Reply Quote 0
        • NitroFreak
          NitroFreak @dc42 last edited by
          Hi dc42, thank you for answering so quickly.
          No, the E1 heater output is not to spare sadly.
          I was thinking of using the two PWM ports on the duet expansion breakout board?
          What do you mean by
          Do you mean the mosfet board does not work on 5v?
          If so, do i have to connect it to the board itself?
          Which pins would be suitable for that?
          Thank you
          Max
            The PWM ports provide 5V drive. Check that your mosfet board is ok with that.
            • NitroFreak
              From this "diagram"
              They list that the mosfet is to be connected directly to the old mosfet heated bed output, so i guess 12-24v
              Does that mean that 5v is OK or does that mean that maybe 5V is not enough?
              Thank you
              Max
                dc42 administrators @NitroFreak last edited by
                It means that 5V may not be enough.
                • NitroFreak
                  NitroFreak last edited by NitroFreak
                  To shortly get back to this topic,
                  Indeed the linked mosfets did not accept 5V voltage.
                  I have now gotten some IRF520 Mosfet boards with somewhere around 6.5 amp continuous drain current, which should be enough, and they do work.
                  But i noticed, after switching the solenoids have much less power (maybe half) than if i hold them directly to the 24v power supply.
                  I do not have a multimeter, but it has to mean that the mosfets "steal" voltage.
                  Is that possible?
                  They also get extremely hot from just two seconds of engagement, as if they have a lot of bypass current that gets converted to heat inside the mosfet.
                  Is there any way i can reduce that? Will it help if i put two mosfets in parallel?
                  Thanks
                  Max
                  Stephen6309 1 Reply Last reply Reply Quote 0
                  • Stephen6309
                    Stephen6309 @NitroFreak last edited by
                    @nitrofreak Cheap SSRs usually have a high on resistance and use lower current mosfets, like the fake FOTEKs you can get on ebay.
                    https://duet3d.dozuki.com/Wiki/Choosing_a_bed_heater#Section_Bed_heater_driven_using_a_Solid_State_Relay
                    • NitroFreak
                      NitroFreak @Stephen6309 last edited by
                      @stephen6309 said in driving 24v 4A 6Ohm solenoids, selection of flyback diode:
                      I´m not using SSR´s, i am using mosfets to drive the solenoids.
                      My solution now is to connect the small mosfets to the input of the big mosfets, so as to let the big ones drive the current while the small ones just activate the big ones with 24V.
                      Not pretty, but seems to work until i have a better solution
                      Dougal1957 1 Reply Last reply Reply Quote 0
                      • Dougal1957
                        Dougal1957 @NitroFreak last edited by
                        @nitrofreak said in driving 24v 4A 6Ohm solenoids, selection of flyback diode:
                        I can recommend these Power Expander
                        Doug
