    Duet WiFi firmware new feature priorities
    Firmware wishlist
    54
    167
    40.7k
    • appjawsundefined
      appjaws
      I had no idea that the wish list was so long, what would we do without you.
      Here are my priorities.
      O. Support for restore points. This would allow the print to be paused, a restore point created, and the printer shut down - either automatically because of power failure (although a UPS or SLA battery would be needed to power the printer for a few seconds), or manually. Then the printer could be re-started and the print continued from the same point. Only practical for 3D printers that can be re-homed when there is a print on the bed, or for which the motors can be relied upon to retain their positions if they are shut down at an appropriate full step position.
      B. Multi-threaded web server, capable of supporting several concurrent connections even when one of them is uploading a file. May also increase the speed of file uploading a little.
      J. Dynamically-varying microstepping, allowing true 256x microstepping at low speeds, with microstepping automatically reduced for faster moves.
      M. Babystepping, i.e. ability to change where the printer thinks Z=0 is in small steps during a print.
      C. Predictive temperature control. This will replace PID. Probably the main benefit is that it will have a simple and fast auto tune procedure. implemented in version 1.15
      appjaws - Core XYUV Duet Ethernet Duex5
      firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
      Ormerod 1-converted to laser engraver, Duet wifi
      OpenSCAD version 2024.03.18
      Simplify3D 5.1.2
      • DjDemonDundefined
        DjDemonD
        I might have missed it but did babystepping make it into one of the updates?
        Also will grid levelling be available for delta as well as other kinematics?
        Just read the grid levelling thread.
        www.precisionpiezo.co.uk
          Babystepping is still on the to-be-implemented list. Grid based bed compensation got more votes.
          • Huguesundefined
            Hugues
            A filament tracking with encoder plug to an endstop pin can be my request on firmware wishlist !
            • A Former User?
              A Former User
              What about adding an access point mode somehow?
              For example if you want to travel with your Duet you don't need to reconfigure another WiFi connection.(Not with your smartphone, notebook or a foreign access point)
              When the Duet doesn't find the preconfigured WiFi there could be an additional access point mode option in the WiFi setup menu (192.168.1.1).
              • Adamfilipundefined
                Adamfilip
                Can Enable auto sleep by turned on my default?
                  @Adamfilip:
                  Please define what you mean by auto sleep.
                  Currently the default behaviour is that when all motors have been inactive for 30 seconds, the motor currents are reduced to 30% of normal. The timeout and percentage are configurable.
                  • Doowrednuundefined
                    Doowrednu
                    In another thread it was discussed to add an exception for trigger 0 so that it was prioritised over running macro events. Purpose being to have the ability to add a physical emergency stop using a micro switch
                    Is this possible?
                      @Doowrednu:
                      Is this possible?
                      That's already coded in 1.17RC1, although I haven't tested it or measured the latency yet.
                      • Reanimator2kundefined
                        Reanimator2k
                        @dc42:
                        G. Support for three independently-controlled Z motors, normally moved in sync but moved independently when performing bed leveling (and I really do mean bed levelling, not bed compensation).
                        I just want to thank you for this being in a new feature list.
                        And i have a question if this is a proper thread. Is it possible to do a two side filament diameter measurement with live adjusting printing parameters depending on filament diameter?
                          @Reanimator2k:
                          Possible in principle, but to do it accurately I think it would need two linear CCD sensors and probably lenses. Unless you are extruding your own filament, it's probably not worth while IMO because most filament has good diameter accuracy these days.
                          • elmoretundefined
                            elmoret
                            @Reanimator2k:
                            http://www.thingiverse.com/thing:454584
                              Reanimator2k
                              @dc42:
                              Yes, i want to use my own filament(From Filastruder 2) and yes, you get my bad English right, dual CCD sensors is what i want. Not a must have thing, but i think it will increase quality of my prints and make my printer more userfriendly.
                              @elmoret:
                              I saw this, not my thing, i want dual sensor because filament may have an oval profile.
                              • elmoretundefined
                                elmoret
                                Mount two at 90 degrees to each other, average the result.
                                But the filament should good quality. A Filastruder should achieve +/-0.05mm fairly easily and +/-0.02mm with some tweaks assuming properly dried/processed pellets.
                                • Qdeathstarundefined
                                  Qdeathstar
                                  I have a suggestion;
                                  When the printer goes into "heater fault" why not just pause the print and shut off the heater that is at fault, instead of ruining a whole print… That way, after we clear the fault and check to make sure there are no issues, we can just resume printing...
                                    @Qdeathstar:
                                    Good idea. I have added it to the work list.
                                    • Russ Griesundefined
                                      Russ Gries
                                      I'm not sure if this has been noted before or not, but ill address it here and you can correct me if its fixed.
                                      here is my scenario, I set up a print to run at 30mm/s, however along the way i see its running well so i bump it up to 60mm/s
                                      ( 200% of speed) now when the print is finished the delta tries to home or move some where else to get out of the way and its also at 200% of speed.
                                      and that's when things get ugly….
                                      and if for some reason it it dose make it to that location with out crashing and i forget its at 200% of speed, its almost guaranteed that it will crash trying to move to the first position of that next print.
                                      I have all my other moves confined set at just the right speed ( Homing, max travel speeds) , so if its over 100% things get crazy.
                                      is there a way to set the % of speed to only be that when running the print? i'm sure you can add it to the G code but i would think it could be built in so others done experience the same problem?
                                      i use that speed function all the time to run tests and all kinds of stuff.
                                      also dose the higher % of speed also over ride the config files max speeds?
                                      Thanks!!
                                      ~Russ
                                      One Day At A Time…
                                      My Main Research Page:
                                      http://rwgresearch.com/open-projects/3d-printing-research/
                                      • DjDemonDundefined
                                        DjDemonD
                                        Hi Russ,
                                        Yeah I had this issue so now I use M220 S100 in my end gcode and in my cancel.g so any time a print ends I return to 100% speed before homing and begin at 100% for the next print.
                                        I also find for autocalibration I reduce my accel/jerk and speed then return it to normal within my bed.g.
                                          Russ Gries
                                          OK, thanks for the reply, i still wonder if it can be integrated in the firmware??
                                          also i could add to the pause.g for when i want to do that, but when i start back up i guess ill need to change the speed again.
                                          say is there some kind of script that can be used so " get" the current speed, then put it back after a pause.g?
                                          any how. ill add those to my .g files for now!!! Thanks!!
                                          ~Russ
                                          One Day At A Time…
                                          • T3P3Tonyundefined
                                            T3P3Tony administrators
                                            Hi Russ
                                            Thanks for pointing this out. Interesting question about how and when we want the firmware to overwrite the commands entered by the user in a non obvious way. My perspective (personal view entirely) is that we want the firmware to stay as the user set it until there is a reset or a fault. So if you have changed a speed, temp, acceleration, or any other variable that is what it stays at.
                                            That said there may be very good reasons to deviate in specific cases.
                                            www.duet3d.com
