    Duet WiFi firmware new feature priorities
    Firmware wishlist
    54
    167
    40.1k
    • Russ Griesundefined
      Russ Gries
      @dc42:
      Yes, the speed slider uses M220.
      Currently the speed of homing moves does get affected by M220. This is one of the reasons that I am thinking of changing M220 to affect printing moves only, so not travel or homing moves or retractions. Firmware retractions are already not affected by M220.
      ok, thanks David!
      yeah, I've had a lot of experience with marlin, and homing in not effected by speed settings. However even marlin will crash on the start of the print if the speed % is set way to high. That first move from home to the bed is a "Print" move.
      with that said, it would be smart to have the the homing moves not be effected by the % speed settings.
      I'm not sure if there is an easy way to do it within the firmware with out other things being effected.
      I do agree with others that if the %speed is set to xx value then it constantly being overwritten is a pain.
      Is there was a way to " read" the value of the % speed setting? Then we could set up a simple line of code at the beginning of the home.g file to read and save that % speed in memory, then set it to 100% run the homing stuff, Then at the end just wright back to where it was ???…
      the same with all other things we all ways want to run at 100% of speed. like bed probing and stuff ( I'm not sure if that speed is effected or not?) but we could use that command to read speed setting> do something at 100'%> wright back speed setting from before.
      this might be a useful thing for other things as well...
      any how just a thought, I'm not even sure is possible from the front end ( code) or if its something already there i don't know about..
      Thanks!!
      ~Russ
      One Day At A Time…
      My Main Research Page:
      http://rwgresearch.com/open-projects/3d-printing-research/
        On option would be to have the speed setting included when the firmware saves parameters before executing a macro file. Then you could use M220 S100 at the start of the homing files, bed.g etc. But then you wouldn't be able to define a macro that e.g. sets the speed to 150%.
        • botundefined
          bot
          I wouldn't go much farther than disabling the speed override for homing. If maximum speeds are set for all axes, and they are reasonable, no crashes should ever occur. In my opinion, max speeds should be set so that no g-code can cause undesirable behaviour. If I accidentally home my printer at 10,000% speed, it will (presumably, I haven't tried it) home at the max Z speed of 60 mm/s. Isn't that what limits are for? If your printer is crashing upon first move, limit the Z speed to one that will not cause a crash.
          *not actually a robot
          • Shenundefined
            Shen
            When you implement "Support for three independently-controlled Z motors" can you also add support for two independently-controlled Z motors? I have two motors on each side of the heated bed, and I believe this isn't an uncommon setup.
              Yes I will be supporting 2, 3 and 4 independent Z motors.
              • Simspeedundefined
                Simspeed
                @dc42:
                Hi David…We talked on the RepRap forum about using 2 Z motors and multiple belts to sync the 4 corners of the XY carriage on my fixed bed (non-adjustable) Core XY build. You confirmed that Duet will soon have ability to independently control and sync multiple Z motors. Since I have 4 lead screws supporting the XY carriage in Z motion, will it be feasible to do away with the belts and run separate motors on each screw to level the XY carriage to the frame mounted bed? I'm at a stage where I can add two additional Z motors to the build for little cost. If you see this as a practical scenario I'd like to make that change now and be ready when the firmware upgrades are in place. Thanks...TP.
                Custom C-Beam H-Bot - Hard mount 560mm x 800mm MIC 6 bed plate - 3mm PEI print surface- 120v mains silicone bed heater (3 zones) - 800mm Z axis - polycarbonate enclosure - (4) .09° Nema 23s (Z) - .09° Nema 17s (XY) - Bondtech extruders - E3D Cyclops hotend, 24V power supply
                  Yes you can do that. You will need a DueX5 expansion board so as to have enough drivers. Until the new firmware is ready, be prepared for the motors to get slightly out of sync when you power cycle the printer.
                  • Simspeedundefined
                    Simspeed
                    So then I assume a thumb knob at the top of each shaft would allow one to manually adjust the four corner back to level after power up. Will we eventually be able to probe the four corners through a program routine to level the XY carriage to a fixed bed?
                      Yes, that's correct. You might want to temporarily reduce the Z motor currents using M913 while doing the adjustment.
                      • InSanityundefined
                        InSanity
                        Not a very useful feature for most people, however I would love to see support for the Z-endstop being a safety for the Z-Probe homing. I've crashed the nozzle into the bed sooo many times while messing around with Z-Probes of different natures all while that mechanical Z endstop switch is triggered but doing nothing. I know, not many people would care. I guess I could wire that in to kill the machine if it's triggered somehow. So I guess my request would be for support for mechanical Z endstop while using a Z-probe for homing.
                        Jeff
                        Duet WiFi Powered FFCP with E3D legends hotend system. BLTouch grid leveling.
                        • deckingmanundefined
                          deckingman
                          @(In)Sanity:
                          Jeff
                          You can do that already (I have). Just wire the mechanical switch to a spare end stop (say E1) then use M581 - something like this M581 E1 S1 T0 C0.
                          • InSanityundefined
                            InSanity
                            I'm going to expand on my request to say, if any endstop is triggered stop trying to move in that direction. It's crazy you can get the printer in a state where it hits the endstops but just keeps on grinding away. It seams like some kind of Sanity check would be useful.
                            Thanks,
                            Jeff
                            • InSanityundefined
                              InSanity
                              @deckingman:
                              @(In)Sanity:
                              Jeff
                              Ok, I just moved my Z-Endstop over to E1 and did as you suggested just changing S1 to S0 due to makerbot style endstops. Works like a charm, if I dig the nozzle in even a little bit past normal calibration it just shuts down….love it!! So now I guess I need double trigger endstops to do this on the X and Y also. Easier in software.
                              Thanks,
                              Jeff
                                There's nothing to stop you having the shutdown trigger if the X and Y endstops are activated too. Just change the command to:
                                M581 X1 Y1 E1 S1 T0 C0
                                but you will have to disable this during homing, obviously!
                                • InSanityundefined
                                  InSanity
                                  @dc42:
                                  That is a fantastic idea. Thank you!
                                  Jeff
                                    deckingman
                                    Something else I did was to install switches on all the axes maxima, wired together in series and connected to yet another spare E stop. Then if I do something stupid like send an axis beyond it's maximum position before I've homed it, then it'll trigger an emergency stop before the frame gets mangled. I also have a physical emergency stop button wired the same way to yet another spare. It isn't a true emergency stop in that it doesn't cut all power - if I want to do that, I just press the button on the RCD I use to kill everything.
                                    • InSanityundefined
                                      InSanity
                                      @deckingman:
                                      That's a good idea. It would be kind of neat if the firmware had the option to Not travel in a direction opposite of the end stops if you've not already homed. That way it would prevent some stupidity on the users end (myself). I've implemented the X Y and Z endstops triggering trigger2.g which I then just put an M112 in the file. Why did I go with the file…IDK...seamed like a good idea. It shuts off during homing moves except for homing the Z axis which is for really bad situations.
                                      Thinking about it the option to prevent Non Homing moves if not homed would be good. Pretty much if your not seeking a home during a move and your not already homed prevent the move. Just a thought.
                                      Jeff
                                      • LeonMFundefined
                                        LeonMF
                                        @(In)Sanity:
                                        This is incredibly common in industrial motion controllers. I also think this is a fabulous idea.
                                        Current: Railcore II ZLT w/Duet 3 and Hemera hot end.
                                        Retired: Robo3D R1,BI V2.5 Delta updated to BerryBot magnets, bespoke carriages and Duet Ethernet, M3D Promega;
                                          deckingman
                                          @LeonMF:
                                          @(In)Sanity:
                                          I can think of a couple of scenarios where that might not be such a good idea. For a example, if you finish a print and turn the machine off, then when you next turn on the machine, you need to move the Z axis out of the way in order to remove the print that's still stuck to the bed. If it's screw driven, it could be a pain to move it by hand and if your only option is to move Z towards home you'd be a bit stuck. It'd also be a pain during commissioning, when you are trying to sort out motor wiring and rotation directions.
                                          • minimundefined
                                            minim
                                            @deckingman:
                                            @LeonMF:
                                            @(In)Sanity:
                                            It could be a flag that's normally checked so you just uncheck it to confirm that you know what you are doing if it's needed. Or it could pop a confirm box when you try to move a axis away from home so you had to click OK to allow the movement. I have done this mistake with my printer a couple of times and even if I know it will happen I do forget it sometimes.. A notification saying "don't do anything stupid" would help 😄
