    Can't upload gcode files - Duet Web Control
    Duet Web Control
    • _santiserrano
      _santiserrano last edited by
      Hi, when I try to upload gcode files it gives me an error, the speed is reduced to about 7.4 KiB/s and it gives me an error message. I don't think it is the wifi connection nor the SD card. Any idea? It is the first time using this DUET wifi board, I am using 2.02 release with duet web control 1.22.6 and duet wifi server 1.22. I can't control the machine via the DWC but the only thing I can't do is upload gcode files. Any help? Thanks in advance.
        Can you send M122 in the console and post the results here?
        You may want to check the troubleshooting for wifi here: https://duet3d.dozuki.com/Wiki/WiFi_disconnections_and_AJAX_timeout_errors
        • _santiserrano
          Hi, thanks! I will read the troubleshooting guide. The M122 command gives me the following results:
          M122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet WiFi 1.02 or later
          Board ID: 08DDM-9FAM2-LW4SD-6J9F4-3SJ6N-9LZRY
          Used output buffers: 3 of 20 (9 max)
          Static ram: 25524
          Dynamic ram: 98624 of which 0 recycled
          Exception stack ram used: 280
          Never used ram: 6644
          Tasks: NETWORK(ready,544) HEAT(blocked,1232) MAIN(running,3788) IDLE(ready,200)
          Owned mutexes: WiFi(NETWORK)
          Last reset 00:48:52 ago, cause: software
          Last software reset at 2019-02-07 20:46, reason: User, spinning module GCodes, available RAM 6500 bytes (slot 1)
          Error status: 0
          Free file entries: 10
          SD card longest block write time: 10.4ms, max retries 0
          MCU temperature: min 37.1, current 38.3, max 38.5
          Supply voltage: min 12.0, current 12.1, max 12.2, under voltage events: 0, over voltage events: 0, power good: yes
          Date/time: 2019-02-07 21:35:36
          Slowest loop: 20.37ms; fastest: 0.07ms
          I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
          Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
          Scheduled moves: 0, completed moves: 0
          Bed compensation in use: none
          Segments left: 0
          Movement lock held by null
          http is idle in state(s) 0
          telnet is idle in state(s) 0
          file is idle in state(s) 0
          serial is idle in state(s) 0
          aux is idle in state(s) 0
          daemon is idle in state(s) 0
          queue is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 39.10ms; fastest: 0.00ms
          Responder states: HTTP(0) HTTP(1) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
          HTTP sessions: 1 of 8
          • WiFi -
            Network state is running
            WiFi firmware version 1.22
            WiFi MAC address 60:01:94:34:37:ff
            WiFi Vcc 3.37, reset reason Turned on by main processor
            WiFi flash size 4194304, free heap 26136
            WiFi IP address 192.168.0.104
            WiFi signal strength -70dBm, reconnections 0, sleep mode modem
            Socket states: 0 2 0 0 0 0 0 0
            Phaedrux Moderator @_santiserrano last edited by
            @_santiserrano said in Can't upload gcode files - Duet Web Control:
            That's borderline for wifi signal.
            Is the Duet blocked by any metal printer frame?
            If possible, relocate either the printer or the router so they can be closer together to test for better signal strength.
            _santiserrano 1 Reply Last reply Reply Quote 0
            • _santiserrano
              _santiserrano @Phaedrux last edited by
              @phaedrux said in Can't upload gcode files - Duet Web Control:
              together
              Ok, so you think it is for that reason? The printer is a bit far from the modem, yes. I will try relocating it, thanks for all. But it is normal that all works good but the files upload only? Thanks
                The transfer speed of the upload will suffer greatly if the router and the Duet can't establish a good connection. It will try and drop the speed to improve transfer reliability, but with the usually large multi megabyte gcode files there is a good chance that they will error out at such a low transfer speed.
                If you find that a stronger connection solves the problem, but you can't easily relocate the router or the printer, possible solutions include adding a wifi repeater or router in the same room as the printer.
                • oliof
                  oliof last edited by
                  I had this problem once, and it turned out the microsd card was not properly seated in it's slot. Just removing it and reinserting it making sure the retaining mechanism engaged fixed it for me.
                  You should still try to improve the wifi coverage as suggested. My printer currently resides at the edge of the covered wifi area, and it surely leads to performance issues (even with the Duet Web Control) when additional blocking factors (like people moving around or the printer frame being between the laptop and the access point).
                  <>Creality CR-20 IDEX Duet3 mini 5+<>RatRig V-Minion SKR RRF 1.1<>
