tpost.g does not apply tool offset
3.1k
  • undefined
    smoki3
    I have a similar machine like the e3d tool changer. I am now trying to tweak the tool changer scripts.
    So now I noticed that the tpost.g doest not apply the tool offset. I try to call the nozzle clean feature in the tpost.g script. Then my printer is crashing because the tool offset is not applied at this moment.
    Is this by design or a bug?
    For me it makes no sense. Because if the tool offset is not applied in this script we can simply just use the tpre.g script. For my understanding the tpost.g script will be executed "post" the tool change. That means the tool is already aktive. But every movement is without the tool offset.
    • undefined
      I agree, that doesn't sound right. I'll look into this next week.
      • undefined
        I can't see anything wrong with how it is coded. However, just before the tpost.g file is run, the firmware updates the current user position based on where the head currently is. For example, suppose tool 0 has an X offset of -10mm and Y has an X offset of +20mm. You are using tool 0 and you move it to X=50. The head reference point will be at X=60. Then you execute T1. Assuming the tfree file doesn't move the head, at the start of tpost.g the HRP is still at X=60. So the current user X coordinate will be set to X=80, which is where the nozzle of tool 1 is.
        Your situation is slightly different if you are using a tool changer. In your tpre file you are moving the X coordinate of the HRP to the correct position to pick up the tool, say it is at X=100. If the nozzle is 10mm to the right of the HRP, then the nozzle is at X=110, so when tpost starts the current X coordinate will be changed from 100 to 110. If your intention is to move the nozzle over a brush to clean it, this is exactly what you want.
        If you still think there is a bug, please provide your tool change files and explain in more detail which tool change causes a problem and what happens.
        • undefined
          smoki3
          Thanks for you feedback. As I understand you explanation then we are on the same side.
          But I have a Nozzlebrush script as an macro. Lets call it "nozzlebrush.g".
          This macro moves the nozzle of any tool to the brush and clean it.
          As soon I call this macro in tpost.g then my printer crashes, because at the moment the nozzlebrush.g is called still the old coordinate system is active.
          If I run first T1 and after the tool change is finished i call nozzlebrush.g my printer is not chrashing and moves as it should to brush.
          These are roughly my scripts:
          tpre.g
          G1 X50 F18000 ; Xpos of tool1
          G1 Y200 ; Ypos of tool1
          M280 P5 S180 ; lock tool
          G1 Y100 ; move away from dock
          tpost.g
          M116 P1 ;wait heater
          G1 Z0 R2 ; recovery Z Pos
          M98 P"/macros/nozzlebrush.g"
          nozzlebrush.g
          G1 X220 Y100 F18000 ; brush pos
          G1 Y80 F1000
          • undefined
            In which axis is the tool offset that you say is not being applied?
            • undefined
              smoki3
              It in X and Y axis. I did now a detailed analysis and I unfortunately broke my printer 😞
              But I have some results:
              This is my tool offset:
              G10 P2 X5.32 Y46.45 Z-13.12
              and this my tpost.g
              M116 P2 ; wait for heater
              M106 R2 ; restore fan
              G1 E5 F2000 ; unretract after tool change
              M703 ; filament config
              G1 R2 Z0 F720 ; move Z to print position
              G1 X189 Y175 ; added for testing
              M42 P5 S0 ; Turn off servo
              So my expectation is that the nozzle is after the tool change at pos. X189 Y175. But it isn't - it is at X194.32 Y221.45.
              You can see the printer moves without the tool offset to the marked position and than applies the offset. I also can see this while moving on the paneldue. After it finished the movement then it applies the offset.
              I hope it get more clear now.
              • undefined
                smoki3
                case GCodeState::m109ToolChange2:	// Select the new tool (even if it doesn't exist - that just deselects all tools) and run tpost
                		if (LockMovementAndWaitForStandstill(gb))		// wait for tpre.g to finish executing
                			reprap.SelectTool(gb.MachineState().newToolNumber, simulationMode != 0);
                			UpdateCurrentUserPosition();					// get the actual position of the new tool
                			gb.AdvanceState();
                			if (AllAxesAreHomed())
                				if (reprap.GetTool(gb.MachineState().newToolNumber) != nullptr && (gb.MachineState().toolChangeParam & TPostBit) != 0)
                					String<ShortScratchStringLength> scratchString;
                					scratchString.printf("tpost%d.g", gb.MachineState().newToolNumber);
                					DoFileMacro(gb, scratchString.c_str(), false);
                		break;
                Does UpdateCurrentUserPosition(); apply the tool offset? Should there not something called like tooloffsetTransform?
                undefined 1 Reply Last reply 16 Feb 2019, 10:30 Reply Quote 0
                • undefined
                  dc42 administrators @smoki3
                  @smoki3 said in tpost.g does not apply tool offset:
                    	gb.AdvanceState();
                    break;
                  UpdeateCurrentUserPosition calls GetCurrentUserPosition (which is a misnomer because it actually returns the machine position in Cartesian coordinates), then it calls ToolOffsetInverseTransform to work out the user coordinates that correspond to that machine position.
                  PS - which firmware version are you using?
                  • undefined
                    I confirm that the behaviour is not as expected. I created a tool with G10 X and Y offsets of +10mm each, and I put G1 X50 Y50 in the tpost file. It ended up at X60 Y60 in user coordinates.
                    I will investigate this.
                    undefined 1 Reply Last reply 16 Feb 2019, 11:00 Reply Quote 0
                    • undefined
                      smoki3
                      This post is deleted!
                      • undefined
                        smoki3 @dc42
                        @dc42 said in tpost.g does not apply tool offset:
                        Thanks! I am ok fw 2.02
                        • undefined
                          I've found the reason for the difference in behaviour. Whenever any system macros are run automatically, RRF uses machine coordinates not user coordinates. The primary reason for this is to avoid applying workplace coordinate offsets. For example, if you are using workplace coordinates and you want to home the machine or do a tool change, then you don't want to apply the workplace coordinate offset to the moves that home the printer or swap the tool. Following a discussion with CNC users several weeks ago, RRF treats tool offsets in the same way as workplace coordinate offsets.
                          If you never use workplace coordinate systems, then a workaround is to select a workplace coordinate system in your tpost file. For example, you can put G54 at the start of tpost.g to select workplace coordinate system #1.
                          For the future, it might make sense for RRF to ignore workplace coordinates in system macro files but to apply tool offsets (they would then be applied in the tfree and tpost files, but not in tpre because on tool is selected at that point). Bear in mind that this would affect your tfree file, because the XYZ coordinates that you move the tool to when docking it would be adjusted by the tool offset; unless you used G53 to specify machine coordinates.
                          undefined 1 Reply Last reply 16 Feb 2019, 12:03 Reply Quote 0
                          • undefined
                            smoki3 @dc42
                            @dc42 that's wired. May it make sense to don't apply it to the system macros but as soon a user macro is called it uses the tool offset.
                            Because for tpre and tfree it makes sense to be independent from the tool offset.
                            Or we have a bit in M98 to choose which coordinate system is called
                            undefined 1 Reply Last reply 16 Feb 2019, 14:09 Reply Quote 0
                            • undefined
                              I don't see why it would make sense in the general case to apply tool offset by default to tpost but not to tfree, because in either case a tool is selected.
                              I can think of a few solution:
                              1. Provide a command to specify that you don't want workplace coordinates to be used but you do want to use tool offsets. Possibly a parameter to the G53 command.
                              2. When conditional GCode and variables are implemented, you will be able to add tool offsets explicitly if you need to.
                              • undefined
                                smoki3
                                I think in tfree you don't need tool offset because your "dock" is in the absolute coordinate system.
                                But if have tested the G54 command in the tpost.g. Now everything works as it should. And it does not influence tfree and tpre.
                                • T3P3Tonyundefined
                                  T3P3Tony administrators
                                  Following on from this - and other tool changer discussions. For me the logical behaviour is:
                                  No tool selected (T-1): No tool offsets applied.
                                  Tool selected (Tn): G10 Pn tool offsets applied.
                                  That behaviour should endure no matter if a user or system macro is executing, or wherever the gcode is coming from. It creates significant confusion to have any other behaviour, especially where macros are tested by sending lines of g-code individually from the console first - and then putting them in the macro
                                  Furthermore the tool change system macros should definitely adhere to this so:
                                  Tpre - no tool is selected (T-1 state). no offsets applied
                                  TPostn -Tn is selected so tool offsets for that tool are applied.
                                  TFreen - Tn is still selected until this macro completes so offsets are applied (by definition, this is the macro that frees up the tool so the tool is still selected until this macro completes).
                                  If the workspace co-ordinates should not be applied to system macros then that exception should be built into the workspace coordinate logic - not pollute the tool logic.
                                  I get that conditional gcode would allow this to be worked around - but this should be the default behaviour.
                                  www.duet3d.com
                                  • mhackneyundefined
                                    mhackney
                                    David, we've been discussing this in the E3D tool changer slack channel where there has been some confusion about how to set up firmware tool changes. A number of us were not using tpreX.g and instead "doing everything" in the tpostX.g. This has led to inconsistent pickups. I'm surprised it has worked at all but my machine has been commissioned since early January and I've done 1000s of tool changes. But every so often, a tool pickup goes wrong. This usually results in a "minor" crash but the the tool was still able to be picked up. For a while I attributed this to sensor-less homing not being consistent and needing some attention. But yesterday I just happened to be watching a tool pick up and noticed on the PanelDue the X coordinate was not what I was expecting. It was the tool dock position in machine coordinates - X305.0 - PLUS the tool offset in X which was 0.15. So I was seeing X305.15 and expected to see X305 - the position in machine coordinates that I used to configure dock positions.
                                    But this was not consistent. Sometimes I'd see X305.0. It seemed to depend on whether this was the first tool being picked up or a new tool being changed in.
                                    Long story short, I found this thread and thought about it and posted in the channel where Tony was responding to my questions. I now understand that the issue was that some/all/most of us in the E3D beta30 group are not using tpre macros - we do the tool pick up in tpost and tpre is empty.
                                    I now understand what coordinate system is used with these scripts and that accounts for the "sometimes" odd behavior. It is surprising to me that it worked at all in retrospect.
                                    In thinking about this and Tony's comments above, it seems that the tfree is still a bit unclear. Tony uses tool coordinates for his tfree but I and others use machine coordinates, yet that works - sort of, most of the time. I like the idea of explicitly putting a G53 in tfree before doing the undock movement sequence. I've implemented that and with the minimal testing, things seem much smoother. But, how about this proposal to clarify, simplify documentation and usage and provide the full range of functionality:
                                    Proposal for clarifying names and consistency:
                                    • tdockX.g - machine coordinates, script to dock the tool
                                    • post-dockX.g - tool coordinates, anything you need to do after picking up the tool, like wiping
                                    • pre-undockX.g - tool coordinates, anything you need to do before releasing the tool
                                    • undockX.g - machine coordinates, undock the tool script
                                    This would be clear (I have to admit that I find "post" by itself confusing. In CNC world we use "post" when discussing the post processors in our CAM to generate the g-code and I have a mill that refers to putting back a tool as "posting") and would simplify and clarify documentation while providing the needed functionality
                                    My 3D Printing blog: http://www.sublimelayers.com
                                    Coming this summer: "3D Printing Strategies - the art of perfecting your designs and prints"
                                    T3P3Tonyundefined 1 Reply Last reply 28 Feb 2019, 16:20 Reply Quote 0
                                    • T3P3Tonyundefined
                                      T3P3Tony administrators @mhackney
                                      Hi @mhackney thanks for posting all the background and your proposal. I think dock/undock would be equally confusing for all those who use the tool change macros but without a docking mechanism. The best example of this is the "mixing" hotends with multiple inputs and one output.
                                      The naming aside, I think that at any point the tool is physically on the pickup head, tool coordinates should apply. Any time the tool is not on the pickup head, machine coordinates should apply. This has the advantage that you can troubleshoot individual lines in the tool change macros confident that what is observed when lines are entered individually is what will happen when the macro is run, anything that breaks this behaviour concerns me.
                                      www.duet3d.com
                                      mhackneyundefined 1 Reply Last reply 28 Feb 2019, 17:02 Reply Quote 0
                                      • mhackneyundefined
                                        mhackney @T3P3Tony
                                        @t3p3tony good point about tools, I've been in "tool changer world" for a few months but have printers with mixing tools (Cyclops, Diamond) as well.
                                        Regarding your comment about when the tool is on the pickup head, my comment on this regards docking the tool. It seems error prone to require using the tool coordinate system to dock a tool that is on the head. That's why I suggested a new tool change file on the undocking side that would be in the machine coordinates.
                                        I suppose David's comment above about using G53 to change to machine coordinates in the tfree scripts would suffice and that is what I am implementing now.
                                        I also noticed in some tool change configuration (not sure if E3D was the source or one of the beta testers) that there were two scripts in /sys
                                        offseton.g and offsetoff.g
                                        Here is an example of offsetoff.g:
                                        ;R - Standby
                                        ;S - Active
                                        ;Z - Subtract = up
                                        ;Tool 0
                                        G10 P0 X0 Y0 Z0
                                        ;Tool 1
                                        G10 P1 X0 Y0 Z0
                                        ;Tool 2
                                        G10 P2 X0 Y0 Z0
                                        ;Tool 3
                                        G10 P3 X0 Y0 Z0
                                        I think the intent was to move the G10s to this file and take them out of config.g
                                        Then, one could call the offsetoff macro when they needed to move in machine coordinates and offseton when they need to move in tool coordinates. I do not know the origins of these and how they are actually configured (as both were X0 Y0 Z0). Perhaps someone here knows.
                                        • mhackneyundefined
                                          mhackney
                                          David, I'm investigating further because even after modifying my tool change scripts, I am seeing odd behavior.
                                          My T3 has a dock position (machine coordinates) at X305.0 - so it is convenient to watch.
                                          I created a tpreX.g files for each tool that positions to the machine coordinates for each tool and picks up the tool then backs out.
                                          I edited my tpostX.g files to remove all code except the wait for the hot end to warm up and then call a macro to wipe the nozzle on my wipe brush
                                          I edited my tfreeX.g files to add a G53 before any movement code to dock - which is all in machine coordinates and matches the coordinates in the tpre files
                                          Now the fun begins... (I'll post the files for T3 at the end of this)
                                          I homed and clicked Select in the Tools tab in Settings. I watched the head move to X305.1 !!! and dock harshly. I then undocked and that was also done at X305.1.
                                          Firstly, my T3 X offset in G10 is X0.15 (not 0.10).
                                          Wanting to dig in a bit I decided to put some debugging "print" statements in. So I added print code at the entry and exit of each of the 3 files like this:
                                          M400
                                          M118 P0 S"enter tpre3: "
                                          M114
                                          (with the appropriate string in M118 of course)
                                          I also added the print to tfree3.g after I do a G53 to change to machine coordinates. That looks like:
                                          G53 ; move to machine coordinate system
                                          ; move to dock
                                          G1 X305.0 Y190.0 F15000
                                          M400
                                          M118 P0 S"moved to dock in tfree3: "
                                          M114
                                          Notice that I do a move to X305.0 after calling G53 and then the print messages happen
                                          So now, I again home and run the tool change for T3 with the Select/Deselct buttons.
                                          Here is the output for Select followed by Deselect T3 (starting with an empty tool head):
                                          ANALYSIS
                                          From the bottom up of the logs:
                                          So from bottom up (first command is at bottom):
                                          CLICK SELECT
                                          • tpre3 was called and it movement happening in machine coordinates
                                          • T3 issued - this must be coming from the firmware before tpost3 is called
                                          • tpost3 is entered - this is done BEFORE tpre3 was completed! X position is in tool coordinates (X305.15)
                                          • tpre3 is exited and once again in machine coordinates X305.0
                                          • tpost3 is exited
                                          CLICK DESELECT
                                          • tfree3 is entered
                                          • T-1 issued
                                          • move to dock X305.15 is in tool coordinates - this was printed AFTER G53 was called and a movement in X was made. It should have been X305.0 from my understanding
                                          • tfree3 is exited and left in tool coordinates
                                          So I am completely baffled by a few things...
                                          And this of course depends on if this data is reliable...
                                          Where does the initial X305.1 that I observe on occasion come from?
                                          Why is the move to the dock in tpre3.g in tool coordinates X305.15?
                                          I am baffled that my tool changer worked before and even more baffled that it works now!
                                          Here ate the T3 scripts:
                                          2_1551377659258_tpre3.g 1_1551377659258_tpost3.g 0_1551377659255_tfree3.g
