    HomeZ
    884
    • Will Baxterundefined
      Will Baxter
      why is it that my X axis goes the wrong way when i use the HomeZ but homes fine when i use the home x
      Will Baxterundefined 1 Reply Last reply Reply Quote 0
      • aidarundefined
        aidar
        Please post your config.g and homing files.
          Will Baxter @Will Baxter
          @will-baxter config.g file
          Configuration file for Duet WiFi (firmware version 1.21)
          ; generated by RepRapFirmware Configuration Tool on Sun Jan 13 2019 13:36:28 GMT+0000 (Greenwich Mean Time)
          M550 PBaxters beast ; Set machine name
          M551 Pboomboom6663 ; Set password
          M552 S1 ; Enable network
          M586 P0 S1 ; Enable HTTP
          M586 P1 S0 ; Disable FTP
          M586 P2 S0 ; Disable Telnet
          M569 P0 S0 ; Drive 1 goes forwards
          M569 P4 S0 ; Drive 4 goes forwards
          M569 P5 S0 ; Drive 5 goes forwards
          M569 P6 S1 ; Drive 6 goes forwards
          M584 X0 Y1:2 Z3:4:5 E6
          M671 X390:219:0.0 Y400:10:400 S4 ; leadscrews at front left, front right and rear middle
          M92 X80 Y79.9 Z386.5 E420 ; Set steps per mm
          M203 X6000 Y6000 Z180 E1200 ; Set maximum speeds (mm/min)
          M201 X500 Y20 Z250 E250 ; Set accelerations (mm/s^2)
          M906 X800 Y800 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X390 Y400 Z600 S0 ; Set axis maxima
          M574 X2 Y2 Z0 S1 ; Define active low and unused microswitches
          M558 P1 I0 R0.4 F300 X0 Y0 Z0
          G31 X0 Y0 Z-0.1 P600
          M557 X25:375 Y15:395 S50 ; Define mesh grid
          M140 H-1 ; Disable heated bed
          M143 H1 S300 ; Set temperature limit for heater 1 to 260C
          M106 P1 S1 I0 F500 H T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
          M106 P2 S1 I0 F500 H T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
          M563 P0 D0 H1 ; Define tool 0
          HomeZ.g file
          homez.g
          ; called to home the Z axis
          G91 ; relative positioning
          G90 ; absolute positioning
          G1 X15 Y15 F6000 ; go to first probe point
          ;G91 ; relative positioning
          ;G1 S2 Z5 F100 ; lift Z relative to current position
          ;G90 ; absolute positioning
            Will Baxter @aidar
            @aidar just posted them any help would be appreciated
            • aidarundefined
              aidar
              Can you post homex.g as well?
                Will Baxter
                homex.g file
                ; homex.g
                ; called to home the X axis
                G1 S1 X-395 F1800 ; move quickly to X axis endstop and stop there (first pass)
                G1 X5 F6000 ; go back a few mm
                G1 S1 X-395 F360 ; move slowly to X axis endstop once more (second pass)
                G1 Z-5 F6000 S2 ; lower Z again
                  Do you mean it goes the wrong way when you home all? or home z?
                  Can you post the rest of your homing files?
                  Where are your end stops located?
                  Where is your 0,0 origin position?
                  When you home, does the head travel towards the origin?
                  • aidarundefined
                    aidar
                    I see from your files , that you are homing x to min end (G1 S1 X-395), but in your config x endstop is configured as max end (M574 X2 ....), so something is messed up here. If you answer to Phaedrux questions, then we can help better.
                      Will Baxter
                      x axis goes the wrong way when i home all
                      my end stops are located bottom left corner
                      my origin is located bottom left corner
                      when i home the head travels towards origin
                      ; homeall.g
                      ; called to home all axes
                      G1 S1 X395 Y405 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                      G1 X5 Y-5 F6000 ; go back a few mm
                      G1 S1 X395 Y405 F360 ; move slowly to X and Y axis endstops once more (second pass)
                      G1 X60 Y60 F6000 ; go to first bed probe point and home Z
                      ; homey.g
                      ; called to home the Y axis
                      G1 S1 Y405 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                      G1 Y-5 F6000 ; go back a few mm
                      G1 S1 Y405 F360 ; move slowly to Y axis endstop once more (second pass)
                        @will-baxter said in HomeZ:
                        If your end stops and origin are located at the bottom left I would expect these values to be negative rather than positive, since you want it to move towards 0.
                        In your home X it moves in the negative direction, so I think that's your issue. You'd have to change the direction of the next move which pulls away from the endstop abit before going back more slowly.
                        Make sense?
