    Pinda V2 Probe wiring
    1.4k
    • Krohm Koalaundefined
      Krohm Koala
      Hi, i'm working on prusa i3 mk3 bear built from an anet a8, i'm going to use the mk3 bed and i wanted to use a pinda v2 probe but i don't how i can wire it, because of the thermistor, maybe the thermistor can be wire to the mod pin of the probe header ? Also since i haven't paneldue, i was thinking of using the 5V and GND of the paneldue connector to power it, don't think it'll be a problem, no ?
      So here's a recap of the wiring (mostly for myself 😃 ) :
      Thermistor -> Probe_Mod
      5V + GND -> Panel Due Connector
      Signal -> Probe in
      Should be okay or i need to change the thermistor wiring ?
      Have a nice day !
        dc42 administrators @Krohm Koala
        For now I suggest you leave the thermistor wire not connected. RRF currently supports compensating the trigger height based on the bed temperature only.
          Krohm Koala
          Thanks, I'll do that, so no problems with my wiring ?
          Will it support this type of thermistor in the future ? BTW if it already compense with the bed temperature, it's a good thing 🙂
            Yes I plan to make the temperature channel used for trigger height compensation configurable.
              Krohm Koala
              Oh nice ! Really happy with the choice of this board !
