    H1 giving erratic reads while printing.
    2.3k
    • DocTruckerundefined
      DocTrucker
      What's the logic behind having a 0.5 duty limit?
      As I understand it this is only really useful if the heater responds too quick for the Duet to control it. If the mosfets fail on the 0.5 setting won't happen anyway and the heaters will be locked on 100%. If the thermistor drops out of its hole and gives a false low won't the heater fault detection pick this up quickly?
      I did however have it on my mind an age ago to go seriously overpowered and fuse it so if it went 100% it would pop a fuse. Still want to try that. May need a little coil in the circuit to tame the spikes a little, with a corresponding flywheel diode.
      • pao_wikhanundefined
        pao_wikhan
        okay its happening again. now im not sure if my duet is broken
          dc42 administrators @pao_wikhan
          @pao_wikhan said in H1 giving erratic reads while printing.:
          Are you using the thermistor or the PT100 now?
          pao_wikhanundefined 1 Reply Last reply Reply Quote 0
            pao_wikhan @dc42
            new thermistor, on that pic..
            i replaced it with the one included in e3d v6, seems stable so far. but i didnt connect it to the daughter board as its not giving any values.
              pao_wikhan
              if it happens again, i think the heatblock screw holding the sensor is not gripping correctly, but that is a long shot. (my theory that is.)
                DocTrucker
                If you over tightened that it may edge towards occasional shorts. Too loose wouldn't cause spikes like that. That's got to be an electrical or control board issue. I doubt there are real situations survivable for the temp sensor where it could loose heat that quick - even if yanked out of the heater block.
                  If it's a thermistor (not a PT100) then negative-going spikes like that suggest a bad connection, or just possibly static discharge from the hot end metalwork to the thermistor wire. But I think they are too frequent to be static discharge.
                    pao_wikhan @dc42
                    well 4hrs into printing, i think the e3d sensor (blue wire) did the trick. odd though cause when i measure the resistance its like 70k-100kohm and not the pt100 value of below 100ohms. its now cleaner than ever. i also replaced the cartridge and moved back to a newer 24V 50W ceramic type with 100% pwm.
