Nozzle heater dudes....
  • Hi,
    i am having issues with Nozzle heater, the temperature dont rise....
    In this moments, its conected to E0 socket in Duet.
    I have try to connect to socket E1... but when try to asign the heater, conected in E1, to the active tool with Duet web control.... its greyed.
    Before chage to E1, when heater its conected to E0, i haved this in config.g
     M307 H0 B0 S1.00                                                        ; Disable bang-bang mode for the bed heater and set PWM limit
     M305 P0 T100000 B4066 C8.950070e-8 R4700                                ; Set thermistor + ADC parameters for heater 0
     M143 H0 S120                                                            ; Set temperature limit for heater 0 to 120C
     M305 P1 T100000 B4193 C7.060000e-8 R4700                                ; Set thermistor + ADC parameters for heater 1
     M143 H1 S280                                                            ; Set temperature limit for heater 1 to 280C
    The questions are
    A- What the procedure to conect heater cardtridge to E1 and asign to current tool ?
    B- Why heater cartdrige conected to E0, seems labeled how P1?
    C- How its labeled heater cartdrige conected to E1? Maybe P2?
    thanks
  • E0 connected heater is P1 cos P0 is bed heater. So yes, heater on E1 will be P2.
    Are you sure your current heater (P1) is correctly defined in tool? Like M563 P0 D0 H1.
    Attension! In M301, M303, M307, M563 heaters are H, in M305 they are P
