Tevo Little Monster initial setup
Some days ago, i have changed config.g, in my Tevo Little Monster... And now, i am having issues after 2 layers, maybe 3.... I think its a geometrical problem, after change config,g, M665 changed.....
Now i start print ok.... but in 2 layer maybe 3 layer, nozzle start scratch printed part.... i Suppose is a M665 issue, but i am not sure what are the corrects values.... i have find this in facebook TLM Duet users group.....
Can someone that have this printer tellme the correct M665
I have find these:
Set delta radius, diagonal rod length, printable radius and homed height Ver. 1 --> M665 R157.0741 L397.19 B157.0741 H520 Ver 2 --> M665 R150 L360 B170 H550 Ver. 3 --> M665 R150 L398 B150 H524.871 Ver. 4 --> M665 R157 L397.1073 B175 H525 I have (12/02/2019) --> M665 R157 L397.1073 B175 H489.0 First Test (12/02/2019) --> M665 R157 L365 B160 H489
This is mine:
M665 R170 L397.19 B155 H525 ; Set delta radius, diagonal rod length, printable radius and homed height
I changed the R value it was 155.
Hope this helps
Andy
@tef9 said in Tevo Little Monster initial setup:
thanks to all help me to find the way.
After adjust M665 in config.g, great print.... Its only a test object.
And the measures.... very aceptable.
Teorical measures are 30x30 mm and 20 mm between horizontal lines.
Printed dimensions are 30.23x30.30mm and 19.67 mm between horizontal lines
