    Sensing tool head offset
    My Duet controlled machine
    • DDDundefined
      DDD
      I'm working dual toolhead setup. T0 regular FDM extruder and T1 a syringe-based paste extruder. With any change, let's say a new needle, the needle will be off every time.
      Is there a way to measure and set the needle-offset by passing it through a series of different opto-endstops, let say X' Y' and Z'?
      This is with the intention of using a macro after homing T0 to set the T1 offset automatically.
      • Dr_Ju_Juundefined
        Dr_Ju_Ju
        Have you considered fitting a Precision Piezo sensor (https://www.precisionpiezo.co.uk)
        You just home the z axis each time you do a tool change, and with appropriate tweaking, should give you what you want.
        Julian,
        Old goat, learning new things….
        • DDDundefined
          DDD
          Interesting those Precision Piezo sensors. However, the needle is too flimsy to make physical contact with any surface, it must be a contactless system.
            Use the G30 S-2 command. It will do a single probe and then set the Z offset of the current tool so that the stop height matches the configured trigger height.
            • DDDundefined
              DDD
              Is there a way to probe the X and Y offset, similar to the G30 command for Z
                dc42 administrators @DDD
                @docdiegoc said in Sensing tool head offset:
                There is the M585 Probe Tool command. This command is likely to be extended in firmware 2.03.
                • DDDundefined
                  DDD
                  I'll take a look.
                  Thanks for the fast answers.
                  I've been working with Marlin and Smoothieware, but the Duet it's a superior solution to anything I have seen. Congrats and keep up with the excellent work.
