New Duet 2 Wifi, wifi module starting...
  • Just got my second Duet 2 Wifi (been running one in another printer for over a year) and I can't get the wifi to work on it. The wifi module isn't showing a blue led and YAT just says "Wifi module is starting" but it never actually starts. Here's the results of sending M122;
    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet WiFi 1.02 or later
    Board ID: 08DGM-917NK-F23T0-6JKDJ-3S86R-TWBDF
    Used output buffers: 1 of 20 (1 max)
    Static ram: 25524
    Dynamic ram: 98840 of which 0 recycled
    Exception stack ram used: 256
    Never used ram: 6452
    Tasks: NETWORK(ready,1872) HEAT(blocked,948) MAIN(running,3868) IDLE(ready,200)
    Owned mutexes:
    Last reset 00:02:28 ago, cause: software
    Last software reset details not available
    Error status: 0
    Free file entries: 10
    MCU temperature: min 31.8, current 32.6, max 32.8
    Supply voltage: min 1.7, current 1.7, max 1.7, under voltage events: 0, over voltage events: 0, power good: no
    Driver 0: ok, SG min/max not available
    Driver 1: ok, SG min/max not available
    Driver 2: ok, SG min/max not available
    Driver 3: ok, SG min/max not available
    Driver 4: ok, SG min/max not available
    Cache data hit count 267658661
    Slowest loop: 99.60ms; fastest: 0.06ms
    I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
    Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
    Scheduled moves: 0, completed moves: 0
    Bed compensation in use: none
    Heater 1 is on, I-accum = 0.0
    Segments left: 0
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 0
    serial is ready with "M122" in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 0.18ms; fastest: 0.00ms
    HTTP sessions: 0 of 8
    • WiFi -
      Network state is starting
      WiFi module is disabled
      ok
    Any help would be appreciated.
    Please try reinstalling the WiFi firmware. It should already be on the SD card, so you can send M997 S1 to reinstall it.
  • Thanks for the reply. Well, I'm trying to post the results of sending M997 S1 but Aksimet keeps blocking it as spam. But it's failing due to comm write error.
    Edit: https://pastebin.com/3ChFUAVq
    Tried a different USB port on my computer with the same results. I think the wifi module is dead. Which sucks. I expect a controller that costs $170 to have been tested. I'm sure FIlastruder will replace it but they can't replace the time I've spent troubleshooting or the time I'll now have to wait on a new one to arrive or for this one to be repaired.
    The WiFi module needs to be replaced. As Filastruder to replace your Duet.
    I assure you, all Duets that we and our distributors sell are tested before shipment, and that includes testing WiFi connectivity.
  • Yeah. I get to ship it back on my dime so they can pick through it for a couple days. Then, if they don't find a way to blame it on me, they'll send a replacement. Last time I do business with Filastruder.
  • That is not true, your replacement has already been approved, as stated in the email. We [Filastruder] just need your board back first, as is the case with most warranty programs.
  • Yeah, that's a pretty standard policy. But this isn't a standard product. If I wanted standard, I'd buy a $30 MKS board off amazon and if it was DoA, I'd expect to have to jump through a few hoops to get it replaced. Instead, I bought a premium product from an authorized distributor for a premium price.
