    Fan1 ON when bed is hot
    728
    • pabomanundefined
      paboman
      What is the correct line to put in the config to turn on FAN1 when the bed reach 50°C ?
      thx
      • Stephen6309undefined
        Stephen6309
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M106_Fan_On
        should be: M106 P1 T50 H0
        • pabomanundefined
          paboman
          thank you !
          • pabomanundefined
            paboman
            Why the fan connected to FAN1 never stop even with M106 P1 S0 ? it just slow down
              dc42 administrators @paboman
              @paboman said in Fan1 ON when bed is hot:
              Because if you select thermostatic mode, RRF assumes that you want it to turn when the temperature is above the set point ni order to protect something from overheating. So it protects against turning the fan off until the temperature drops.
              • pabomanundefined
                paboman
                thank you dc42.
                Can I put in the config two or more commands for the same fan?
                I want the FAN1 turn on if the bed is above 50° AND if the cpu or any driver are above 40°C
                  Phaedrux Moderator @paboman
                  @paboman yes you can specify Multiple heaters and temps using H#:#:# and T#:#:#. Replace # with your numbers.
                    dc42 administrators @Phaedrux
                    @phaedrux said in Fan1 ON when bed is hot:
                    You can only specify one temperature range H<low>:<high>, or alternatively a single temperature. So you will need to choose one temperature between 40C and 50C for the fan to come on.
