Slic3r PE upload (and, optionally, print) functionality
  • I just installed Slic3r (Prusa Edition) and found that I could enter the IP address (hostname) of my duet controller and it didn't seem to require any login credentials to be able to upload and start a print job remotely. How does that work?
    Thanks,
    Chris
    It's probably using the default password, and you haven't changed the password of your Duet. See https://duet3d.dozuki.com/Wiki/GCode#Section_M551_Set_Password.
  • Either I have something funny in how I setup my Duet or this sounds like there is a security problem.
    I am running:
    WiFi Server Version: 1.21
    Web Interface Version: 1.22.6
    and I just verified that I cannot log into the web interface using the password "reprap" but I can with the custom password I have set using M551 in my configuration. I just learned a little about the rr_* rest interface and I find that I can run:
    curl http://tlm-duet/rr_status
    curl http://tlm-duet/rr_filelist?dir=0:/gcodes
    curl http://tlm-duet/rr_mkdir?dir=0:/gcodes/test
    and most surprisingly:
    curl 'http://tlm-duet/rr_gcode?"gcode=0:/gcodes/inner.gcode"'
    (where tlm-duet is the hostname of my printer and inner.gcode exists).
    and my printer starts printing. For fun I also tried adding in a bogus password:
    curl 'http://tlm-duet/rr_gcode?"gcode=0:/gcodes/inner.gcode"&password=ajfdlkajfla'
    and that also successfully started the print. I have verified the same behaviour on 2 different printers both running the same version (one on a Duet WiFi and the other on a Duet Maestro).
    If you are already running DWC on the same PC, then that IP address will already be authenticated and any commands from that PC will be allowed.
  • Wow, that is pretty magical!
    For this testing, I was logged into DWC in an X windows session (linux) and running these commands using a terminal that I connected to remotely, I just closed Chrome in the X windows session and it now correctly rejects these commands due to authentication failure.
    I guess it is doing IP based authentication?
    After logging back into the DWC on that machine, I created a new user and logged in remotely via ssh as the new user and that user could control the DWC via curl without requiring authentication.
    Which does seem like a smaller security hole but not as bad as it seemed.
    Yes, it does IP-based authentication. The HTTP request only tells us the sending IP address and port number, and the port number keeps changing.
  • Hi Guys,
    I've been experiencing a spot of bother using Slic3r STD edition.
    Is Slic3r Prussa Edition better than Slic3r for a Kossel XL+ ?
    Thanks,
