    Connected to access point but Site can't be reached
    Duet Web Control
    • chriskimbrundefined
      chriskimbr
      Duet2Wifi M552
      WiFi module is connected to access point ButterBean, IP address 192.168.1.42<LF>ok<LF>
      When i go to ipaddress in http://192.168.1.42 get error;
      "This site can't be reached".
      Any ideas on why webpage won't load? It was working then stopped.
        Two common reasons:
        1. Wifi signal strength too low. Send M122 and look for the WiFi signal strength (RSSI) in the report.
        2. Your router has stopped talking to the Duet. Try rebooting the router.
        chriskimbrundefined 1 Reply Last reply Reply Quote 0
          chriskimbr @dc42
          @dc42 Fixed it.
          in config.g file...
          was set to this for some reason;
          M552 S0 ;Disable HTTP
          Needs to be ;
          M552 S1 Enable HTTP
            I didn't think of that! I'm glad you solved it.
