    Incorrect wiring diagram?
    • tomasf
      tomasf last edited by
      I noticed that the Duet WiFi wiring diagram (https://duet3d.com/wiki/Duet_WiFi_wiring_diagrams) seems to have the CONN_SD and CONN_LCD connectors reversed. In reality (at least according to the PCB silkscreen), CONN_LCD is actually the outer one (closest to the power connector side).
        You are right, CONN_SD and CONN_LCD are swapped over in that wiring diagram. I expect Tony will correct it soon.
        • T3P3Tony
          Thanks for pointing this out Tomas, I have updated the diagram:
          www.duet3d.com
          • tomasf
            Great! Thanks!
