    How do I wire the stock ender 3 endstops to the duet wifi
    • bay3d
      bay3d last edited by
      Hi, I'm sure this is a dumb question but I can't figure out how to wire the stock ender 3 endstops to the duet wifi, the guide says for endstops with two wires (which is what the ender 3 has) to use ground and signal, but when I look at the wires connected to the ender 3 endstops they say signal and voltage.
      If anyone has done this before and could explain how they wired it that would be fantastic. I've looked around the internet but I can't seem to find an answer to this.
      • JamesM
        JamesM last edited by JamesM
        Give me a few minutes and I'll check mine for you.
        EDIT: They are wired to the outside pins on the duet's endstop connectors. I only use X and Y since I have a bltouch for my Z.
        bay3d 1 Reply Last reply Reply Quote 0
        • bay3d
          bay3d @JamesM last edited by
          @jamesm do you know which wire is which when compared to the original connectors? If not how would I figure it out
            From the photo they are evidently 2-wire microswitch endstop. So connect the two wires from the X endstop switch to the two outer pins of the X endstop connector. It doesn't matter which way round. Similarly for the Y endstop.
            • JamesM
              The switches have 3 connectors but that's only so they can be used as NO or NC(only 2 wires are connected to them). I just used them how they were wired on the machine. In my config.g this is my endstop line M574 X1 Y1 S1
