Unsolved Delta calibration failed
And Voilà !!!!
Look at this That's much better compare to the previous one :))G32 Calibrated 7 factors using 19 points, deviation before 0.022 after 0.021
M665 Diagonal 289.536, delta radius 170.580, homed height 229.474, bed radius 114.0, X -0.089°, Y -0.175°, Z 0.000°
And the rod length is quite the same compare to measurement I did.
The distance between balls of the carriage and balls of the effector was not the same. The max difference was 0.9mm
The carriages of my printer have a screw to tight them much or less on the V-slot profile. But when you tight them you change the distance between the 2 balls, which cause a major issue on the geometry of the printer.I still have a small tilt effect on the effector, but I think that the precision should be now enough to print large parts.
I'll give a try and let you know. -
The result is better, mostly for the first layer but it could be improved further.
What are the other reasons which can tilt the effector ?I have printed a large rectangular object which should measure 120x170mm, but in fact the print is smaller and not rectangular, the shape is trapezoid
Only the height is correct. -
@viald said in Delta calibration failed:
The common reasons are listed at https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer#Section_Make_sure_your_build_is_accurate.
Step by step checks
Towers must be parallel to each other
My Delta has metal corners. I have checked spacing with a caliper at bottom, top and half way. the max difference between 2 towers is less than 0.2mmBed should be at right angles to the towers in both X and Y directions
I have checked with a square, the bed is perpendicular to the 3 towersAll 6 rods must be the same length, measured between bearing centres
Checked, see above.The spacing between the bearings at the top of a pair of rods must be exactly the same as the spacing between the bearings at the bottom
Corrected, see aboveThe joints must have enough angle of movement to allow the nozzle to reach all of the printable area
I use magnetic balls, not an issue.The two bearings on each carriage must be at the same height
Should be by design, I don't know how to check.Carriages must not be rotated or warped about the Z axis
It should not be my case. Check the video with the bulls-eye level. I suppose If one of the carriage has this issue, the level should move during mouvement along the Z axe.There must be no play in the joints
I use magnetic ballsI have printed this calibration tool https://www.thingiverse.com/thing:745523
M665 L289.536 R170.677 H227.388 B114.0 X-0.504 Y-0.516 Z0.000
It seems that autocalibration failed to correct the Y tower position. And it seems that I have a rod length error as well, but all lengths are equal
Now that you have corrected the rod bearing spacing, what does the spirit level show?
One question...
The images showed... Are the result of auticompensation.... What are the results of autocalibration? Do you do an auticalibration before autocompensation?
@peirof Yes sure, Before doing an autocompensation I always did autocalibration. My first goal is to have a good autocalibration.
@dc42 As I'm not able to solve the effector tilt effect on the edge of the bed, I set in the beg.g a radius of 70 mm instead of 140 using 13 points (This is the radius of the calibration tool above)
G30 P0 X0.00 Y70.00 Z-99999 H0 G30 P1 X35.00 Y60.62 Z-99999 H0 G30 P2 X60.62 Y35.00 Z-99999 H0 G30 P3 X70.00 Y0.00 Z-99999 H0 G30 P4 X60.62 Y-35.00 Z-99999 H0 G30 P5 X35.00 Y-60.62 Z-99999 H0 G30 P6 X0.00 Y-70.00 Z-99999 H0 G30 P7 X-35.00 Y-60.62 Z-99999 H0 G30 P8 X-60.62 Y-35.00 Z-99999 H0 G30 P9 X-70.00 Y-0.00 Z-99999 H0 G30 P10 X-60.62 Y35.00 Z-99999 H0 G30 P11 X-35.00 Y60.62 Z-99999 H0 G30 P12 X0 Y0 Z-99999 S7
Here is the result of 2 autocalibrations
14:32:51 M666 Endstop adjustments X-0.31 Y0.60 Z-0.29, tilt X0.62% Y0.12% 14:32:48 M665 Diagonal 287.262, delta radius 169.759, homed height 227.619, bed radius 114.0, X -0.516°, Y -0.286°, Z 0.000° 14:32:27 G32 Calibrated 7 factors using 13 points, deviation before 0.009 after 0.006 14:31:53 M666 Endstop adjustments X-0.30 Y0.57 Z-0.28, tilt X0.62% Y0.12% 14:31:49 M665 Diagonal 286.994, delta radius 169.712, homed height 227.628, bed radius 114.0, X -0.554°, Y -0.313°, Z 0.000° 14:31:31 G32 Calibrated 7 factors using 13 points, deviation before 0.244 after 0.004
And the result of Autocompensation
When I print the calibration tool. Angles between Y/X and Y/Z are almost perfect. But the distance are still wrong. X 49.86 Y 50.50 Z 50.23
Small errors in scaling can be corrected using the M579 command.
