    Need some help getting the Duet wifi + bltouch to cooperate
    1672
    • Eldrad
      Eldrad last edited by
      While i have been 3dprinting for a couple of years i havent done much fiddling until recently. I have recently upgraded my duplicator I3 v1 to run with the Duet wifi board in place of the old melzi. After much fiddling with settings it now works well (and amazingly quiet with the new drivers). I have now got a BLtouch probe which i have spend the last week banging my head against the wall to get it to cooperate. I have read the various guides and each seem to have their own spin on what ports etc to use and have tried a lot of them with no success. Luckily part of my problems were solved when i spotted on this forum a post about the cable not being right and checked the probe extension cable which wasnt in correctly. any chance one of you fine people could have a look over my settings and see where im going wrong ?
      Config.g homez.g and homeall.g are included
      The bltouch is plugged into H7 as per this guide https://betrue3d.dk/bltouch-on-duet-wifi-configuratio-and-usage/
      Thanks in advance
      config.g
      G21 ; Work in millimetres
      M569 P0 S0 ; Drive 0 goes backwards
      M569 P3 S0 ; Drive 3 extruder goes backwards
      M906 X855 Y855 Z1080 E855 ; Set motor currents (mA)
      M201 X1000 Y800 Z100 E5000 ; Accelerations (mm/s^2)
      M203 X12000 Y12000 Z120 E3000 ; Maximum speeds (mm/min)
      M566 X600 Y600 Z18 E10 ; Maximum jerk speeds mm/minute
      ; Z-Probe bltouch
      M307 H7 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
      M558 P9 F100 H7 R0.3 T7000 A3 B0 ; Set Z probe type to switch and the dive height + speeds
      G31 P25 X-35 Y-35 Z0.58 ; Set Z probe trigger value, offset and trigger height
      M557 X25:170 Y25:170 S40 ; Define mesh grid
      ; M574 X1 Y1 Z1 S0 commented to add bltouch ; Set active low and disabled endstops
      M574 X1 Y1 S0 ; X home to min. Y home to max. Normally Closed limit switches.
      M574 Z1 S2 ;Define Z to use Probe. Home to Min
      M208 X200 Y200 Z180 ; set axis maxima and high homing switch positions (adjust to suit your machine)
      M208 X-8 Y-8 Z-0.5 S1 ; set axis minima and low homing switch positions (adjust to make X=0 and Y=0 the edges of the bed)
      M350 X16 Y16 Z16 E16 I1 ; set 16x microstepping with interpolation
      M92 X80 Y80 Z400 E98 ; set axis steps/mm
      M307 H7 A-1 C-1 D-1 ; dissable heater 7 for bltouch
      ; Heaters + Thermistors
      M305 P0 T100000 B3950 R4700 H0 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction
      M305 P1 T100000 B4388 R4700 H0 L0 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction
      M307 H0 A193 C719.9 D8.7 B0 ; bed heater settings
      M307 H1 A219 C128 D13.9 B0 ; extruder heater settings
      M570 S120 ; Increase to allow extra heating time if needed ; Set temperature limit for heater 1 to 280C
      M106 P0 S1 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M563 P0 D0 H1 ; Define tool 0
      T0 ; Select first tool
      homez.g
      ; called to home the Z axis
      ; generated by RepRapFirmware Configuration Tool v2 on Fri Feb 22 2019 18:53:04 GMT+0000 (GMT Standard Time)
      G91 ; relative positioning
      M280 P3 S10 I1 ; deploy mechanical Z probe
      G90 ; absolute positioning
      G1 X25 Y25 F6000 ; go to first probe point
      G30 ; Calibrate Z-axis
      M280 P3 S90 I1 ; retract mechanical Z probe
      G1 Z1 F200 ; Raise bed to 1mm.
      ; homeall.g
      ; called to home all axes
      G1 S1 X-205 Y-205 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 X5 Y5 F6000 ; go back a few mm
      G1 S1 X-205 Y-205 F360 ; move slowly to X and Y axis endstops once more (second pass)
      ;G1 S1 Z-180 F1800 ; move Z down stopping at the endstop
      G1 X25 Y25 F6000 ; go to first bed probe point and home Z
      G1 S2 Z5 F100 ; lift Z relative to current position
      • R3play
        R3play last edited by
        A post of your config-override.g also helps
        • Eldrad
          @R3play Thanks for replying. I have checked on my duet and it doesnt have a config-override.g. neither do the files i have downloaded from the reprap configurator to compare with. Is it something i need?
          i dont know whether its relevant but the firmware details are below
          Firmware Version: 2.01(RTOS) (2018-07-26b2)
          WiFi Server Version: 1.21
          Web Interface Version: 1.21.2-dc42
          R3play 1 Reply Last reply Reply Quote 0
          • Eldrad
            If its the config json file then here it is
            {"board":"duetwifi10","firmware":1.21,"nvram":false,"geometry":{"type":"cartesian","mins":[0,0,0],"maxes":[200,200,180],"delta_radius":105.6,"homed_height":250,"low_dive_height":false,"max_carriage_travel":260,"print_radius":85,"rod_length":215,"z_min":0},"drives":[{"direction":1,"microstepping":128,"microstepping_interpolation":false,"steps_per_mm":640,"instant_dv":15,"max_speed":200,"acceleration":1000,"current":855,"driver":0,"endstop_type":2,"endstop_location":2},{"direction":1,"microstepping":128,"microstepping_interpolation":false,"steps_per_mm":640,"instant_dv":15,"max_speed":200,"acceleration":1000,"current":855,"driver":1,"endstop_type":2,"endstop_location":2},{"direction":0,"microstepping":128,"microstepping_interpolation":false,"steps_per_mm":3200,"instant_dv":0.2,"max_speed":20,"acceleration":100,"current":855,"driver":2,"endstop_type":2,"endstop_location":2},{"direction":1,"microstepping":16,"microstepping_interpolation":false,"steps_per_mm":98,"instant_dv":2,"max_speed":50,"acceleration":5000,"current":855,"driver":3}],"idle":{"used":true,"factor":30,"timeout":30},"homing_speed_fast":30,"homing_speed_slow":6,"travel_speed":100,"z_dive_height":5,"slow_homing":false,"probe":{"type":"noprobe","recovery_time":0.4,"trigger_height":2.5,"trigger_value":500,"x_offset":0,"y_offset":0,"speed":2,"deploy":false,"points":[],"pwm_channel":3,"pwm_inverted":true},"num_nozzles":1,"bed_is_nozzle":false,"bed":{"present":true,"heater":0,"use_pid":true,"width":200,"length":200},"chamber":{"present":false,"heater":2,"use_pid":false},"heaters":[{"temp_limit":120,"scale_factor":100,"series":4700,"thermistor":100000,"beta":3988,"a":0.0004671239,"b":0.0002507523,"c":0,"channel":0},{"temp_limit":280,"scale_factor":100,"series":4700,"thermistor":100000,"beta":3998,"a":0.0003055357,"b":0.0002117134,"c":0,"channel":1}],"toolchange_wait_for_temperatures":true,"generate_t_code":true,"tools":[{"mix_ratio":[],"number":0,"name":"","extruders":[0],"heaters":[1],"x_offset":0,"y_offset":0,"z_offset":0}],"compensation_x_offset":25,"compensation_y_offset":25,"mesh":{"x_min":25,"x_max":175,"y_min":25,"y_max":175,"radius":85,"spacing":20},"home_first":true,"orthogonal":{"compensation":false,"height":50,"deviations":[0,0,0]},"network":{"enabled":true,"mac_address":"","name":"wanhao-di3","password":"hunter2","ssid":"thegame","ssid_password":"hunter2","dhcp":true,"ip":"192.168.1.20","netmask":"255.255.255.0","gateway":"192.168.1.254","protocols":{"http":true,"ftp":false,"telnet":false}},"fans":[{"value":30,"inverted":false,"frequency":500,"thermostatic":false,"heaters":[],"trigger_temperature":45},{"value":100,"inverted":false,"frequency":500,"thermostatic":true,"heaters":[1],"trigger_temperature":45},{"value":100,"inverted":false,"frequency":500,"thermostatic":true,"heaters":[1],"trigger_temperature":45}],"custom_settings":"","auto_save":{"enabled":false,"save_threshold":10,"resume_threshold":11,"gcodes_to_run":"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"},"peripheral_points":3,"halfway_points":0,"calibration_factors":3,"probe_radius":85}
            • R3play
              R3play @Eldrad last edited by
              @eldrad
              Thats odd.
              config-override.g is a system generated file.
              I'm no expert at the Duet firmware yet or so.
              So I'll leave it now to someone more experienced than me.
              Maybe sending a M500 command will generate this?
              Eldrad 1 Reply Last reply Reply Quote 0
              • Eldrad
                Eldrad @R3play last edited by
                @r3play said in Need some help getting the Duet wifi + bltouch to cooperate:
                M500
                that did indeed generate it 🙂
                ; Heater model parameters
                M307 H0 A193.0 C719.9 D8.7 S1.00 V0.0 B0
                M307 H1 A219.0 C128.0 D13.9 S1.00 V0.0 B0
                M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                M307 H3 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                • R3play
                  Ok, H7 isn't included in there wich is good.
                  I took a quick look at your config and couldn't find a error immediatly.
                  When sending the following commands, does the BLTouch react?
                  Pin Down: M280 P3 S10 I1
                  Pin Up: M280 P3 S90 I1
                  Self-Test: M280 P3 S120 I1
                  Reset BLTouch + Pin Up: M280 P3 S160 I1
                  • Eldrad
                    @r3play As you have written they dont work.
                    M280 P7 S10 I1 ; Send PWM channel 7 the s10 (angle) command
                    M280 P7 S90 I1 ; Send PWM channel 7 the S90 (angle) command
                    M280 P7 S120 I1; Send PWM channel 7 the S10 (angle) command
                    M280 P7 S160 I1 ; Alarm Release and Push-Pin UP
                    The ones i have written above i have set macros for and they function ok. Looking at it i may have introduced a different p number on one or two things in testing from looking at other peoples guides.. wonder if that is a big issue
                    • R3play
                      @eldrad
                      Try using the guide from Duet itself:
                      https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_BLTouch
                      That's how I have it wired up.
                      Just make sure you connect the wires correctly. (And ofcourse do this when the machine is powered off)
                      Eldrad 1 Reply Last reply Reply Quote 1
                      • Eldrad
                        @r3play Ive changed the pins to match the ones pictured. when i try and run the commands you listed it responds with
                        M280 P3 S10 I1
                        Error: Invalid servo index 3 in M280 command
                        • R3play
                          @eldrad
                          Okay.
                          Now change the following in your config.g file:
                          H7 to H3
                          And delete the following line in config-override.g:
                          • Eldrad
                            @r3play right thats enabled the probe up and down etc
                            • R3play
                              @eldrad
                              Now I would move Z up by a bit for safety and let Z home.
                              What happends when you manually touch the pin back up?
                              Remember, if homing doesn't stop when doing this immediatly click on the emergency stop button in DWC! Else the head will just keep going and crash into the bed.
                              • Eldrad
                                @r3play It deployed the probe that time when diving so thats a big step forward.. but the y axis was out of the way so didnt trigger... now to find where ive cocked up
                                • R3play
                                  @eldrad
                                  okay, but did the machine stop when you manually pushed the probe in?
                                  • Eldrad
                                    @r3play missed that bit. will trigger it again and leg it to the other room to press it in
                                    • Eldrad
                                      Eldrad @Eldrad last edited by
                                      @eldrad that did work, then it went back up and did it again... now to find the bit to move the y axis under the probe... then working out how to mesh level lol.
                                      • R3play
                                        If you clicked Home Z then it calls the homez.g file. And as you can see in that file in doesn't move the Y axis in there.
                                        So if you would click on Home All, it will perform a home all on all axis and this move the bed under the probe.
                                        Glad it's working now!
                                        And good luck on setting it up further 😉
                                        • Eldrad
                                          @r3play Thanks for your help, youve been amazing. solved what i couldnt in minutes 🙂
                                          • R3play
                                            Just noticed you have the following command twice in your config.g
                                            Make sure you delete the following lines in there since you have it already set in the Z-Probe BLTouch section:
                                            Eldrad 2 Replies Last reply Reply Quote 1
                                            • Eldrad
                                              will do, thanks
                                              • Eldrad
                                                @r3play one more question. it throws an error Error: Invalid servo index 7 in M280 command when probing the Z but i cant find any reference to the servo 7 in config.g or the homeall or homez. any ideas?
                                                • R3play
                                                  @eldrad
                                                  if you're using the macros you've sended then change P7 to P3. That should fix the issue.
                                                  • Referenced by  Topenga Topenga
