Need some help getting the Duet wifi + bltouch to cooperate
@r3play said in Need some help getting the Duet wifi + bltouch to cooperate:
M307 H7 A-1 C-1 D-1 ; dissable heater 7 for bltouch
will do, thanks
@r3play one more question. it throws an error Error: Invalid servo index 7 in M280 command when probing the Z but i cant find any reference to the servo 7 in config.g or the homeall or homez. any ideas?
@eldrad
if you're using the macros you've sended then change P7 to P3. That should fix the issue. -
undefined Topenga referenced this topic
