    Change extruder button increments in web interface?
    • rs4race
      rs4race last edited by
      How can I change the increments on the extruder buttons in the web interface? One of my machines runs 3.0mm filament so 2 of the extruder speed buttons aren't usable, I don't know if 60mm/s is even usable with a 1.75mm extruder. Something like 20mm/s 15mm/s 10mm/s 5mm/s 1mm/s would be more usable for me.
      • iDevelo
        iDevelo last edited by
        @rs4race:
        I agree with this. I think any interface settings should also be in a config file so they are persistent across browsers.
        Maybe a json config file?
          The higher speeds are for loading and unloading filament. I agree, there are too many different high speeds available. The 5mm/sec and 10mm/sec speeds are reasonable if using 1.75mm filament, and possibly also 20mm/sec with a Volcano hot end and large nozzle. For 3mm filament with a regular size nozzle, I can see that you would need lower speeds.
          • hairy_kiwi
            hairy_kiwi last edited by
            @iDevelo:
            I'm no web dude, but I was curious enough to search for "json config".
            This webdude says please don't:
            https://arp242.net/weblog/json_as_configuration_files-_please_dont
            The rationale seems solid: apparently there's no way of commenting json config files. He does suggest alternatives however.
            +1 for the feature though - I used a macro as a workaround while setting up for 2.85mm filament fed at 1mm/s max.
            • iDevelo
              @hairy_kiwi:
              @iDevelo:
              Honestly json is fine for what's needed. No need for the user to manually edit it at all and it's easy to parse locally. In theory it would be called through an Ajax request which means it's the ideal format for delivering the data on request.
              • hairy_kiwi
                Thanks for the info 🙂
                • T3P3Tony
                  Having the Web Config settings persist across browsers is a feature request for Chrishamm
                  Duet Hardware Designer
                  www.duet3d.com
